Front windshield wipers stolen
Discussion in 'Gen 3 Prius Main Forum' started by Brian Stark, May 17, 2021.
  1. Brian Stark
    Brian Stark New Member
    Carlsbad, CA USA
    The entire fixture of my front windshield wipers were stolen from my Prius. Is this common? How much would they be worth, I looked online and the arms plus motor were less then $100, Seems like a risky thing to do for such little reward. The car was on my property, really makes me feel
    violated and doesn’t make much sense to me. Could they have been going for more but got spooked?
  2. PriusCamper
    PriusCamper Senior Member
    13,428
    5,421
    Pacific Northwest, USA
    Well, given the severe drought in California you have plenty of time to get them replaced. And no, never heard of this type of theft before. If your car was an older model you could head to a junk yard to get them... But because it's a newer Prius you'll have to try online for some used ones. If all else fails you'll have to buy them new.
  3. Mendel Leisk
    42,305
    They had to pop the hood to accomplish this?
    Grit likes this.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    no risk at all, it takes a few minutes to remove both of them. I remove mine to improve arrowdynamics on a regular basis.
    whatever you do, don’t look up catalytic converter theft on here.
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    owner may have left hood wide open.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,049
    6,923
    Texas Hill Country
    Maybe it was catalytic converter thieves. There is one under that windshield cowl assembly. Come to think of it, the very expensive master cylinder and pump are under there as well. Plus Mendel has everyone paranoid about their egr cooler which is also down there and rather pricey.
    Maybe they were scared off before they got all the goodies. Could be quite a haul. And the beginning of a new crime wave.
    #6 rjparker, May 17, 2021
    Meg&Bear, Merkey, Grit and 1 other person like this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    HAHA!!!...
    Merkey likes this.
  8. Mendel Leisk
    42,305
    Heck the MAF sensor’s around $200 USD IIRC. Lots of good shopping in there.
    Merkey likes this.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    or some friends screwing with you.........
    Raytheeagle likes this.
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Or somebody who is mad at you.
    I would be a bit worried about this.
    Not because of the value of the missing wipers but because of what might come next.
    Meg&Bear likes this.
  11. AzusaPrius
    AzusaPrius Senior Member
    2,253
    942
  12. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,571
    2,602
    Taylors, SC
    My dad tells me that was a common problem in Moscow in the 1980's.
  13. ChapmanF
    18,993
    What 1980s car in Russia had the wipers in a removable cowl?
  14. Mendel Leisk
    42,305
    Yeah I read something: when it would start to rain, there’d be this masse pull-over, all these drivers reinstalling their wipers.
    Georgina Rudkus likes this.
  15. Merkey
    Merkey Active Member
    329
    302
    Birmingham, Michigan
    If they steal the windshield, then no worries about missing wipers.
    TMR-JWAP, qmanqman and Mendel Leisk like this.
  16. qmanqman
    qmanqman Active Member
    444
    153
    CO
    ba dum bum
  17. qmanqman
    444
    153
    CO
    ba dum bum
    Merkey likes this.
  18. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    goggles and microfiber towels will fix that
    Merkey likes this.
  19. Brian Stark
    Carlsbad, CA USA
  20. Brian Stark
    Carlsbad, CA USA
    Hood was shut, the car starts and sounds ok, at least in EV mode, I just backed up and moved forward to test. How do I know just how much they got? Can they get to the catalytic converter through the opening left by the cowl, or anything else? I just recently found out the head gasket is leaking into one of the cylinders. It’s got 230,000+ miles on it, so I was just going to scrap it anyway, can I still risk driving it to the scrap yard? Should I avoid freeway?
