Front Windshield Wipers
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prius08wipers, Sep 26, 2016.
  1. prius08wipers
    prius08wipers New Member
    Hello,
    I was able to use my front windshield wipers two days ago when it was raining. I went to turn them on yesterday to use and they no longer work. This morning I replaced the fuse but they still do not work. I can hear what I believe to be the motor for the wipers running even though they do not move. Is this a common problem to have, and if so what can I do to fix it?
    49,725
    no, sounds pretty rare. are you a good electromechanical diagnostician?
  3. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
  4. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    If you can hear the wiper motor running when turning the wipers on but wipers are not moving then linkage or is wiper gearbox (inside wiper motor assembly) is broken. This is very rare problem so used part should be ok. And you might as well just the whole thing at the same time as andrewclaus is suggesting.
