Frozen & drained HV Battery
Discussion in 'Gen 2 Prius Main Forum' started by PriusOwner428, Jan 16, 2024.
  1. PriusOwner428
    PriusOwner428 Junior Member
    IL
    It's been well below zero these last 4 days. Have a 2008 Prius that sat outside untouched for those 4 days. When I tried to start it today it would not start. Got the red triangle and other HV battery lights. The 12V battery seems OK. The HV battery is showing no charge left at all. Is there anyway to get it started at this point? Even once the temperature goes above freezing, the fact that the HV battery is totally drained will still be a problem.
  2. PriusCamper
    PriusCamper Senior Member
    13,304
    5,378
    Pacific Northwest, USA
    The Battery ECU has some programming to limit or eliminate use of the battery in extremely cold temperatures. So it might be fine once the weather warms up.
    Alternatively, you can use a high voltage trickle charger to recharge it. Maxx Volts and Prolong make them but they're expensive. You can also build your own for $100: Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
    Or this guy near you in Madison might loan you one: EV Powers | Hybrid Battery Service & Repair. Prius Insight Civic. 56 Corry St, Madison, WI
  3. pasadena_commut
    pasadena_commut Senior Member
    2,962
    910
    Southern California
    This sounds about right to me. The battery pack isn't likely to freeze but it might not work very well until the car has warmed up. That doesn't mean that the pack might not have failed just from old age.
    The OP says that the 12V looks OK, but did not provide a voltage. 12V batteries often fail when exposed to low temperatures. I had one drop dead in San Jose after a single cold night (around freezing), despite not having shown any signs of weakness previously.
    If the OP has an electric room heater and a long extension cord it might be interesting to warm up the inside of the car (very carefully, don't want to burn it down!) to at least 40F, for an hour. Pull up the rear tray and the cover over the 12V so that it can warm up too. Then measure the voltage on the 12V, and if that is good, try to start it. If it still has a red triangle get a code reader on it and see what that says.
    PriusCamper likes this.
  4. PriusCamper
    13,304
    5,378
    Yep... We're still in the early days of batteries in cars. Systems that maintain your cells at a precise temperature and even precise humidity and air pressure is something that Tesla and EV makers are realizing giant performance improvements from.
    Someday soon the necessity of preheating and pressurizing your battery pack will be as normal and as expected as turn indicators and headights.
  5. PriusOwner428
    IL
    Looks you might have been right. Just a few degrees warmer today & it started up. Got the HV battery to 60% with a little driving around. Tomorrow will drive it longer to get both batteries recharged. Thanks the reply and the info on chargers.
  6. PriusOwner428
    IL
    It started up today since it was a little warmer. My comment on the state of the 12V was purely subjective based on what I saw light up and work during first attempt at starting it. It was too cold to actually test it back then. thanks for the reply.
