Frustrated in Seattle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by S13orlando, Nov 6, 2016.
  1. bisco
    52,767
    wait, there can't be two grandma's here.:p
  2. Mendel Leisk
    42,251
    My wife is the leadfoot in the family... :whistle:
    52,767
    how many miles on her?
  4. Mendel Leisk
    42,251
    Who we talking about? :ROFLMAO:
    Merkey likes this.
  5. S13orlando
    S13orlando Junior Member
    Orlando
    I was having the Sam issue driving my daughters 2013 Prius earlier this year same route. She drives from Bothell to Seattle now. I just checked her car and it reads 46mpg. I has to. E the hills and the 1.1 mile route to work.
  6. fuzzy1
    10,687
    If her car had the same problem on your route, but gets decent MPG on her route, then the problem is almost certainly the route, not the car.
    Your car is burning nearly as much fuel simply to warm up the engine to operating conditions, as it does to move the car a very short distance. A good solution is to get a car that doesn't need to warm its engine at all -- an electric plug-in model.
  7. S13orlando
    Orlando
  8. S13orlando
    Orlando
    Merry Christmas Prius owners,
    I finally got to take a road trip. Bothell to Port Orchard. 130 miles st 65mph and averaged 47mpg !
    fuzzy1 and Mendel Leisk like this.
  9. fuzzy1
    10,687
    I'll ignore the fact that there is no legal 65 mph anywhere on that route.
  10. S13orlando
    Orlando
    Ok so most of it was 60 mph. These Washington State Troopers are stealthy. I didn't see a one. Either way my crappy local Bothell mpg is the route and not the car. No codes, new Tires ( LRR BRIDGESTONE ) proper inflation (40 psi). Recent alignment. All services up to date. That 1.1 mile up a 30 degree angle or slope is a killer. Merry Christmas. Florida man living in Seattle !
  11. fuzzy1
    10,687
    Around the metro Seattle area, they are mostly absent. I normally see people getting busted elsewhere on my common travel routes. I'm away assisting dad right now. The guy pulled over just behind me yesterday by an Idaho state or county trooper, wasn't creeping up very fast and couldn't have been doing more than 5 over the limit. It was the same area my brother-in-law most frequently gets caught.
    As a reminder, my crude rule of thumb is that each cold start (with the ensuing warmup) consumes as much fuel as 2 miles of fully-warmed-up driving. My Prius can do this with half the total fuel that my old Subaru needed. The only way to improve on the Prius for this short a trip is to use a plug-in car that needs no engine warmup at all -- Hello PiP, Leaf, Volt, Tesla, Bolt, etc.
  12. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    ...each cold start (with the ensuing warmup) consumes as much fuel as 2 miles of fully-warmed-up driving.
    That explains a lot. And I think the 12V battery has something to do with this as well. Before I changed out the battery, the lowest displayed mileage I got on my 2.8 mile morning commute (when the temp was below 30) was 17 mpg! Now, at the same temps, it's consistently closer to 36-38 mpg on the display. (Local roads, in traffic, 11 mph average speed)
    To test that it's the short drive and slow speed, I took a 100 mile drive on the highway this weekend, starting at the same time as I usually commute to work. Cruise control set at 60 mph for 90% of the trip. 52 mpg on the display, 50 calculated after I filled the tank back up.
  13. Mendel Leisk
    42,251
    Tell me there was a reason for this drive, lol.
    A block heater will help, shorten the warm up.
  14. bobzchemist
    507
    342
    It was actually a pleasant Sunday morning drive with my wife, driving up into the hills north of Atlanta.
    Mendel Leisk and Raytheeagle like this.
  15. Mendel Leisk
    42,251
    Sounds like our drive to Harrison Hot Springs, from north Coquitlam, nice fall drive. There's a hot spring heated pool at the destination too.
  16. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    Agree. You should walk.
    No one in Seattle needs a block heater. Umbrellas? Yes.
    #36 William Redoubt, Dec 22, 2016
  17. Mendel Leisk
    42,251
    You're talking to a guy that uses blockheater year 'round, incorrigible.
  18. fuzzy1
    10,687
    OP is disabled, so won't be walking.
    Ordinary drivers don't need them here. But competitive hypermilers can benefit from block heaters in any climate.
  19. Tideland Prius
    16,668
    Agreed. I'm getting 42mpg because of my short trips and hilly terrain without an EBH. It'll be closer to 47mpg if I used an EBH.
  20. Mendel Leisk
    42,251
    Regular use of block heater is beneficial for engine too I think: cold starts are tough on them.
