1. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The air after the aircleaner isn't perfectly clean - if it was, the airflow would probably not exist. My VOLVO had the throttle plate cleaned at about 200,000kms (?), and it didn't look "dirty". I commented that it looked "OK" to the technician, and he said that it's meant to be shiny clean - which is how he left it. Whatever he did, it got rid of the flat-spot for about $50.00.
  2. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
  3. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Tune up on time?
    That's what I thought. Is throttle plate cleaning really necessary though?
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Give us a break, Sam.
    Who and what exactly do you think is wrong ??
  5. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Throttle plate cleaning ... um no. Might they be confused with MAF cleaning? This, however, is something that does need to be done.
  6. Samprocat
    491
    297
    Lincoln, NE
    TPS will need cleaning if the edges are starting to develop build and prevent TPS to come to full 0 position...where MAF will be much more sensitive to any dirt or oil residues....
    Maf is directly related to fuel ECU map...
    Merged. Learn to use multi quote in one post
    Oxygen sensors are also replaceable parts...they don't last forever....with poor tune up and neglect they will fail to read true reading before and after the CAT...
    60+ K miles they should be checked and replaced if necessary..this could be done visual..or using Techstream software.....
    MAF....Sprak plugs....oxygen sensor and health of CAT are directly related to Effectively make best efficient engine...that we see as MPG....
    There is many other aspects to make MPG better or worse....but this is another discussion...
  7. MikeDee
    1,581
    597
    Unfortunately for me, I will probably defer this type of maintenance until a code is set, but where do I find the technical details to perform this maintenance, other than the Toyota repair manual?
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Voodoo magic?
    A scam game?
    I've Been Hoodwinked?
    Bamboozled?
    I didn't land on Plymouth Rock, Plymouth rock landed on me!
    Well, I generally feel claims of wonder probably well overstated. And I hear my money actually crying as it leaves.
    But I do occasionally run a treatment of Techron through my vehicles.
    My logic is that I'm pretty sure it doesn't hurt. If it does help at any level? -Then good for me.
    And if the placebo effect makes me feel $7.95 better about my car and maintenance? Then I got my money worth.
  9. cipsaz187
    cipsaz187 Member
    150
    43
    I use techron twice a year. The engine runs smoother afterwards.
    So I don't mind using it.
  10. Sam Spade
    2,036
    1,024
    2017 Prius c
    And once AGAIN you make a nasty comment without indicating who or what the comment actually refers TO.
    Remember about glass houses and rocks ??
    I think you need to clean up your act first before you throw rocks at others.
  11. Mendel Leisk
    42,364
    I don't think that's Sam talking, more likely one of the moderators, who was on a tear a while back, stamping out multiple postings with single quote per. He finally calmed down, lol.
    Speaking of multi-quote:
    Good question! Maybe the short answer is that it's nigh impossible?
    I'm hoping an Oil Catch Can install in the Positive Crankcase Ventilation circuit might at least slow the accumulation of soot in the Exhaust Gas Recirculation circuit, since that seems to be the main culprit contributing to the oil/crud that builds up in the intake manifold. Maybe.
    Apart from that: periodic, say every 100K kms or so, tear into it and clean it, the whole thing with Brake Cleaner, and follow up with repeated soaks of the cooler with a strong/hot solution of OxyClean.
    #31 Mendel Leisk, Dec 26, 2017
    RCO likes this.
  12. Sam Spade
    2,036
    1,024
    2017 Prius c
    I'm not laughing.
    Any "moderator" who would put text into someone else's posts without indicating who did it should have his license revoked.
    Seriously.
    (Actually did not notice that it was posted in March.)
  13. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    In Lagos, Nigeria, we sometimes use fuel additives to cleanup those carbon crabs. But at that, it seems not to achieve the needed results, so, we tend to remove e the injectors and physically clean them up.
    PS: Fuels here, ha e for somewhat poor quality.
    Dxta
    RCO and Mendel Leisk like this.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I put Brut aftershave in mine, it doesn't do anything but the exhaust smells nice. :D
    alanclarkeau and Raytheeagle like this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Only because you're riding in front of the trail pipe. Those downwind feel the 'Enry Cooper effect. Splash it on! :ROFLMAO::D
    #35 RCO, Dec 31, 2017
    kithmo likes this.
  16. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    FWIW, Henry copper was a British heavyweight boxing champion and the only boxer to put Cassius Clay on the canvas even if he eventually lost the bout. Point was that he advertised Brut Aftershave on TV UK.
  17. Rggaebssplyr
    Rggaebssplyr Junior Member
    Denver CO
    Instead of an additive for the purpose of cleaning the fuel system, what’s the going theory on the once in a while cleaning value of a full tank of premium unleaded fuel? I drive in a high altitude location, therefore I can use regular unleaded instead of mid grade. So the high octane premium is a good jump up.
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Prior to 1995 in the US, Premium gas had more detergents than Regular. Then the EPA regulated the minimum allowed detergent levels and gas companies all gravitated to the minimum allowed. Some automobile manufacturers in 2004 promoted a higher level of detergents called Top Tier.
    Top Tier Detergent Gasoline - Wikipedia
    If you are using a Top Tier gas, the grades all have the same detergents.
    "The Top Tier standards must apply to all grades of gasoline or diesel that a company sells, whether it is economy (low-octane) or premium (high-octane)"
  19. fuzzy1
    10,720
    The regular grade is fine even at sea level. No need for mid-grade octane here.
    Rggaebssplyr and alanclarkeau like this.
  20. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Premium fuel does not automatically have more "detergent" additives than Regular so you are wasting your money. And that is not a "theory".
    Add a bottle of Techron twice a year. Cheaper and you will know what you are getting.
    Rggaebssplyr likes this.
