Fuel additives?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Nalgask, May 12, 2019.
  1. Nalgask
    Nalgask New Member
    North Carolina
    2015 Prius c
    What fuel additive should I use for my 2015 PRIUS C ONE? Or is using that stuff on a hybrid bad? I will be using 0 ethanol gas anyways but just for extra care for my Prius. Also what about fuel injector cleaners as well? Are these safe for my Prius c?
  2. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    If you are using TopTierGas.com gasoline, nothing is needed as detergents are added.
    If you are using non TopTier, then a few tanks of TopTier periodically or adding some Techron once on a while might be good.
    michael.sfo, roadrunner and dubit like this.
  4. Royston.K
    Royston.K Member
    75
    60
    Singapore
    Fine to use fuel cleaner.
    Techron is highly recommended. Also good to high load the injectors for more effective cleaning.
  5. Nalgask
    Nalgask New Member
    North Carolina
    2015 Prius c
    What you mean high load the injectors? Is it a product I purchase?
  6. Mendel Leisk
    42,364
    Can you clarify, in laymen terms?
  7. Royston.K
    Royston.K Member
    75
    60
    Singapore
    Meaning WOT (Wide open throttle) where your injector is working on higher load.
    ztanos and Mendel Leisk like this.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Answer: NONE.
    Except a dose of Techron every 6 months or so; minimum: with each oil change.
    But that does NOT mean what the dealer puts in at 3X the price for exactly the same thing.
    AND.....I think you should do that regardless of what brand of fuel you use.
    I just don't trust the people in the distribution chain to really DO what they are supposed to do.
  9. Mendel Leisk
    42,364
    My wife just took the grand kids to school this morning, just a once in a while thing. One of the schools is up what I like to call "heartbreak hill", 2.1 kilometers of unrelenting steep climb (157 meters). That 13.37% slope on average.
    I put in a does of (Canadian Tire) injector cleaner with the last fill up, so I guess a run like that would help.
    Off-topic: you have to wonder, when community planners locate vital infrastructure, hospitals, schools, do they pay any attention to elevation differences?? There are hundreds of cars daily hauling butt up this hill, thanks to their decision.
    #9 Mendel Leisk, May 13, 2019
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    Injectors don't work like a carb.
    Keeping the injector open a thousandth of a second longer isn't likely to make the solvent work any better.
