Fuel consumption drop
Discussion in 'Gen 2 Prius Main Forum' started by sanlen, Feb 9, 2015.
  1. sanlen
    sanlen Junior Member
    42
    Phnom Penh
    hello,
    My 07 Prius is now at 105237 miles. I used to get more than 55 mpg on highway. However, just lately I always get below 45 mpg. I am thinking of changing the spark plug now.
    Is it the right thing to do? Please also recommend spark plug which fit well with Prius. Other than spark plug, what else should I focus on?
    Thank
    Salen
    52,861
    use the oem plugs. clean the throttle body, check your tyre pressure and test the 12 volt battery. keep in mind, cold weather, slushy streets and winter gas formulation all work to reduce mpg's.
  3. sanlen
    42
    Phnom Penh
    Thank for quick advise. What should I conclude after testing the 12 volt battery?
    52,861
    test it in the morning or after a few hours of being off. if it's less than 12.5 volts, replace it.
  5. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    Changing plugs at 100K miles is a good idea and the recommended change interval.
    However, the most common and most overlooked cause of dropping fuel economy is poor wheel alignment.
  6. alekska
    alekska Active Member
    435
    138
    Atl
    I would not mind to have a fuel consumption DROP (as in OP's title)
    - Alex
    #6 alekska, Feb 11, 2015
    edthefox5 likes this.
  7. Mendel Leisk
    42,352
    Wheel drag might also cause a drop in mpg. Could be misalignment, as mentioned above, brake neglect causing drag for one reason or another, or even low tire pressures.
  8. sanlen
    42
    Phnom Penh
    Thank for advise.
    Just changed the spark plug and made a 600KM trip. I get 51 MPG now.
