Fuel Consumption During Typical Warm-Up
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JBumps, Jul 14, 2014.
  1. JBumps
    JBumps Member
    167
    57
    Morgantown, WV
    2013 Prius Plug-in
    The hack is extremely subtle. After having experienced several installs I think it could be done in a manner such that only a very observant tech would notice. Also, the newest version comes with the Arduous that can be deactivated with the flip of a small switch under the hood - even further lowering the likelihood it would be detected.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    BobWilson measured the fuel consumption during warm-up. Perhaps a search of threads he has started would be fruitful.
    Do note though that his result is not equivalent to wasted energy, since a fraction goes into the battery.
    I cannot remember his method, but anyone with an android and the Torque app could log GPH readings and sum them in a spreadsheet.
    JBumps likes this.
  3. SageBrush
    11,627
    2,533
    Southwest Colorado
    On a tangent --
    The Prius warm-up routine was set in part to keep emissions low. I personally would not care to pollute more to save what is no doubt a small amount of fuel.
  4. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    I curse the engine warmup programming every single morning. My commute is 21 miles and after 18 months of tweaking I have when and where to switch from EV to HV down to the foot. The problem is that on my 35-minute commute the PiP goes through no less than three warmup cycles, and sometimes four, even though ambient is 65°F. The segments needing gas power are separated by a few minutes, which is apparently enough to make the car think it needs to warm up again. The warmup wastes gas because it runs the ICE for far longer than is needed, and by the time it is needed again it will have cooled off again. I can't believe the wear and tear from about 34 hours a year at 2 minutes a cycle is offsetting an even greater amount of wear and tear from something else.
    If my understanding of the PiP's fuel consumption at idle are correct, the unnecessary warmups consume about 12-15% of my total fuel consumption for the commute.
    In my commute case it increases pollution significantly.
    #44 PiPLosAngeles, Jul 18, 2014
  5. bisco
    52,854
    that's why ice not starting at all is the ideal case, disregarding electrical generating pollution.
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    Interesting, thanks for posting.
    Sounds like you may have to compromise with the car. Perhaps all HV for the first ~ 8 miles, and then EV ?
  7. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Warm-Up Cycle? On my 30-minute 17-mile commute, I only have 1.
    Whenever the engine is briefly needed after that, reaching the 130°F threshold only takes a few seconds... which is just a tiny amount of gas. Above it to start with, the shutoff is immediate.
    How long does yours take?
    The only time I've encountered warm-up taking longer is when starting a new trip with an engine already partially warmed. Then it goes for a duration based on runtime rather than stopping at the usual coolant level.
  8. bisco
    52,854
    what was this thread about?:cool:
    JBumps likes this.
  9. PiPLosAngeles
    1,551
    724
    That would significantly reduce my MPG. Right now I can achieve 106 MPG (by the display) for a 42.5-mile round trip with one charge (no possibility to charge at work). I get about 21 miles on a charge currently (my estimated range is currently at 21.8 on startup), but if I had to burn that EV going uphill on the way home it would be significantly less. The only real opportunities for me to improve my MPG are to hack the warmup cycle or go even slower on the highway (I already stick to 55 in the right lane).
  10. PiPLosAngeles
    1,551
    724
    I've always noticed that this car needs two warmup cycles. The first is the longest at about two to three minutes. The very next time the ICE engages - even if it's thirty seconds later - it will perform another mini-warmup (about 1 - 2 minutes). However, on my commute, each use of the ICE is separated by about 10 minutes. The car goes through the full warmup most of the time on each use.
  11. john1701a
    12,840
    5,312
    58
    Maybe your experience has something to do with your EV distance being well above what the typical owner ever has. The longer time might be related to battery reconditioning. Note sure.
    10 minutes in between engine runs with it having shutoff at the minimum would do cause that cycle though.
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    You are getting ~ 50 mpg in HV mode. That is low considering your driving routine and suggests that EV is given the easy part of the route.
    I still think you should try to plan your route differently. Do you have MPG figures for other -- protocols, for lack of a better word ? I'm curious how you would do if you left the car in HV the entire time.
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    Perhaps, but up to 50% of that energy is routed to the battery which in part explains your 21+ EV miles a charge.
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    I was curious how your MPG would work out with more typical EV range and liquid fuel HV values.
    I assumed 60 mpg in HV mode, and 14 miles EV range. That works out to ~ 90 mpg.
  15. woody weaver
    woody weaver Junior Member
    68
    16
    Frederick, MD
    2014 Prius Plug-in
    [50 - 200ml]
    Eggs must be very large in the UK. Using Chicken egg sizes - Wikipedia, the free encyclopedia as a reference (wikipedia knows EVERYTHING!) a large egg is around 70 gr, but it is dense, so only around 45 ml.
  16. bisco
    52,854
    you can look at the sticky spreadsheet for a range of values.
  17. SageBrush
    11,627
    2,533
    Southwest Colorado
    I think I found the SS you mean, but it is locked from view to outsiders.
  18. SageBrush
    11,627
    2,533
    Southwest Colorado
    PiPLosAngeles,
    Fuel economical (but not crazy) driving requires about 200 Wh/mile energy consumption at the wheel.
    I started from that assumption, and
    3 kWh usable battery
    36% ICE efficiency
    42 mile trip
    -> 8400 Wh per trip
    -> -> 5400 Wh liquid fuel
    36% ICE efficiency -> 15,000 wh petrol
    15/33.4 gallons = 0.45 gallons
    42 miles / 0.45 gallons = 93 MPG.
    Calculations like these are what make me skeptical of routines that increase pollution for what seems like at best very moderate improvements in fuel economy.
  19. bisco
    52,854
    42 mile trip - 15 ev miles = 27 hv miles / .45 gallons = 51 mpg.
  20. bisco
    52,854
    that's odd, i don't sign in or anything.
