fuel consumption
Discussion in 'Gen 3 Prius Fuel Economy' started by Ismail Asha, Sep 15, 2017.
  1. Mendel Leisk
    42,249
    Is time not a factor for you? Note the Toyota recommended intervals are always mileage or months, whichever comes first. For example, my Canadian schedule says 8000 kms or 6 months. It's invariably the months that comes first for me, at maybe 4000~5000 kms, and the drained oil looks like this:
    (Worth noting: checking the oil on the dipstick, the above oil will still look very clean. It's only when you get a larger volume in a container that it looks so dark. Also, this is a detergent oil doing it's job, keeping particulate in suspension. Still, food for thought.)
    For comparison, the new oil (in both cases Toyota 0W20):
    #21 Mendel Leisk, Jan 26, 2018
    mjoo likes this.
  2. Ismail Asha
    Ismail Asha New Member
    Amman
    Hello Mjoo
    I use lique moly 0w20 ,its photo attached
  3. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Interesting photo of the used oil. The oil on my dipstick is always clear- sometimes, it's too clear to get a good read. I figured that the rest of the oil was just as clear, but now I know better.
  4. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    There are a few ways to tell when to change the oil. Looking at it doesn't reveal much unless there is a catastrophic problem like coolant leaking into your oil or a bearing that went to lunch. The oil can change color just from the heat of the engine activating the additives. The best time to change can depend on where you drive, when you drive, how hard the car is driven, how long, how good your motor is, etc... Best way is to start with an oil analysis.
    BTW I learned many things reading at bobistheoilguy.com.
    Pixel XL ?
  5. Ismail Asha
    Amman
    Hello Mendel
    Do you think 0w20 work well with the mountains and out temperature 32 F - 108 F ??
    Until now I drive with use this oil 6700 km in 3 months
    So i have to change it.
  6. bisco
    52,761
    sounds like you're fine.
  7. Mendel Leisk
    42,249
    Not sure. For the US Toyota says 0W20, and nothing but. Regardless if you're in Alaska or Texas. Then For Australia, it shows pretty much the entire gamut of oil weights. Personally I take any guidelines with some skepticism. Considering your location, I'd speculated 5W30, year 'round?
    The Australian guideline:
    Prodigyplace and mjoo like this.
