Fuel cost calculations
Discussion in 'Gen 3 Prius Main Forum' started by BZzap!, Feb 28, 2016.
  1. BZzap!
    BZzap! Senior Member
    1,498
    795
    Does anyone know if fuel cost calculations are averaged automatically if you fill up a partial tank at a different cost??Say that you fill up your tank at the half way mark with fuel costing 20% higher than the previous fuel stop. Does the computer then recalculate the FULL tank of fuel at the currently price point or does it average it out?
    sfky likes this.
  2. Virg
    Virg Junior Member
    28
    Austin Texas
    No it does not. You can change the cost per gallon of fuel by using the "trip" buttons on the steering wheel when you fill up; right after you start the car after a fill up. You must do this within about five seconds after pushing the power button.
  3. BZzap!
    1,498
    795
    Yes, I do understand the reset procedure but was just wondering if the fuel cost calculations were averaged with what is left in the tank. Thanks for the reply, none the less.
  4. daddyd302
    daddyd302 Junior Member
    48
    West Allis, Wisconsin
    First off, the Prius isn't as high tech as you wish it could be. What you're asking, the Prius is too dumb to calculate that.
    In addition to what Virg says, the MPG on the Prius is pretty dumb. Do not trust it to give you your MPG. For example it'll say I'm averaging 48 MPG and when I fill up and do the math myself, it's 43 MPG or other times 45 MPG. It's always off by 3-6 MPG. It's always best to fill all the way, otherwise it'll be tricky to calculate your MPG.
    If you can figure out what your MPG is, you'll be able to estimate how many miles you can drive before you need to fill up. I usually fill up around 450 miles. I will usually have about 2 gallons left but I do it anyways to be safe.
    I use gasbuddy to calculate my fuel cost. Some people on here use fuelly.
    GasBuddy.com - Find Low Gas Prices in the USA and Canada
    Fuelly - Track and Compare your MPG
    #4 daddyd302, Mar 2, 2016
  5. VovCA
    VovCA Member
    119
    33
    San Jose
    May be I need setup $1 per gallon, then it is easy scalable.
  6. 348
    348 Junior Member
    71
    36
    Central Oregon
    The only way to accurately calculate your fuel consumption is some simple math after you fill up.
  7. FuelMiser
    FuelMiser Senior Member
    843
    566
    Monument, CO
    I would say NO. It simply uses the current fuel price (from the last time you set it) and the fuel used on that trip to calculate the fuel cost for that trip.
  8. BZzap!
    1,498
    795
    I do have a ScanGauge on board that I programmed to read the fuel level. Maybe I'll see if it has that capability. I guess I'm picking the fly specks out of the pepper.
    Thanks for your spot-on reply.
  9. Oskar
    Oskar Member
    209
    63
    Massachusetts
    I've found this to be pretty much standard. I've owned my Prius for about a year and a half (bought it new) and consistently, since the day I drove it off the lot, there has been a difference of between 3 and 5 gallons from the Prius mpg and the calculated one I do. What is interesting is that the readout from the Prius is always higher. ;)
Loading...
