Fuel Dilution of Engine Oil
Discussion in 'Gen 2 Prius Technical Discussion' started by brick, Dec 24, 2008.
  1. feslope
    feslope Junior Member
    Warren (S.E.) Mich.
    My driving is mostly short trips, 10 miles or less, I usually start and go very seldom any warm up. I take samples hot and am getting no lights or codes. My mpg decline happened about the time I noticed the dilution, decline and dilution have been consistant. Maintenance has been Amsoil 5W30 and filter every 5-6000 miles after 5000 break in with Dino oil. ECM and display were replaced after dilution was noted. Analysis shows no soot or combustion by-products. Until problem was noted analysis consistantly showed <.1% fuel.
    I am the first and only owner of the car and my style has not changed since I have owned it.
    Thanks for your time. Any and all ideas welcome.
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Not sure where to go wrt diagnostics at this point
  3. Patrick Wong
    18,210
    6,526
    Back to basics: how about a cylinder leakdown test? Maybe piston rings on one piston are not forming a good seal with the cylinder, resulting in an excess amount of HC getting into the crankcase.
  4. feslope
    Warren (S.E.) Mich.
    "wrt" "MAF" "CEL" ?
  5. dogfriend
    7,512
    1,191
    Carmichael, CA
    wrt - with respect to
    MAF - Mass Air Flow sensor
    CEL - Check Engine Light
  6. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Oh, hey, how about a blocked crank case ventilation path? I'm not sure how it works on a Prius, but on just about every modern vehicle there's tube (usually with a valve of some sort) that runs from the crankcase to the intake so that normal blowby gasses can be burned up. I suppose a blockage there might promote dilution of the oil. And I mainly suggest it because it's the simplest thing I can think of to test. First, check to make sure that the dip stick stays seated in the tube. (Pressure tends to blow the dipstick out of the tube, with or without messy results.) If you don't see anything that obvious, you can still check to see that there's a vacuum at the dipstick tube while the engine is idling. See if something like a small piece of flat card stock will stay put if you place it over the end of the tube. If it does then I think it's safe to rule out that particular problem. I'm not really optimistic but, like I said, it's an easy check.
  7. feslope
    Warren (S.E.) Mich.
    Thanks, I was wondering how to check that.:)
  8. dcoyne78
    dcoyne78 New Member
    135
    A couple of general comments on fuel dilution. Many Prius owners do have fuel dilution, but do not realize it. Even those who have their oil analyzed may have fuel dilution when their analysis indicates that they do not. Blackstone does not use GC to determine fuel dilution. They have a chart that correlates flash point with fuel dilution and the test is not very sensitive. If you suspect fuel dilution is a problem and would like to address it I would recommend Dyson Analysis.
    Also note that for Blackstone <0.5 % for Fuel dilution is lower than TR which corresponds to more than 0.5 and less than 1 %. Terry Dyson recommends Renewable Lubricants Inc. for cars with fuel dilution issues. It has worked well for my 2004 Prius. A final comment on fuel dilution is that it may cause problems which are not seen in an oil analysis such as excessive varnish buildup in the valve train.
    I agree with Richard that 5000 mile oil changes are a good idea and using a good full synthetic oil may help to mitigate any problems.
    There is more information on my experiences with fuel dilution in the following thread
    http://priuschat.com/forums/gen-ii-...002-miles-mobil-1-0w20-used-oil-analysis.html
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    Another option is to use a test lab that primarily tests commercial engine oils. For heavy duty diesel engines used in mining, road transport, stationary power generation, construction, marine, etc, fuel dilution is of great concern
    Those test labs, like Toromont Caterpillar, are pretty careful about how they test for fuel dilution
  10. Atkinson
    Atkinson Junior Member
    Massachusetts
    Since i changed from very low loading (to achieve MPG) to pulse and glide, I noticed a significant change in gasoline smell on the dipstick. Not a tech measurement, but gasoline smell did bother me at every oil level check.
    Since then, normal motor oil smell with no gasoline detectable.
    Not sure if engine loading affected oil temps or something else...
    One person's observation.
