Fuel Door doesn't close anymore
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by UnceremoniousEnd, Mar 30, 2022.
  1. UnceremoniousEnd
    UnceremoniousEnd Junior Member
    Here
    I have a 2015 Prius Three, and I noticed the other day that the door to the fuel tank doesn't shut properly anymore. Usually it clicks into place, now it just hangs loosely without clicking.
    I believe there is something missing on the inside of the fuel door, next to the gas cap - something that usually catches the door.
    I have done a bit of research, but I'm unsure exactly what piece is missing. I checked and it doesn't appear like anything is broken.
    Can anyone help me out?
  2. PriusCamper
    PriusCamper Senior Member
    13,173
    5,328
    Pacific Northwest, USA
    FInd someone with same car and ask to look at theirs... Or even more ideal find a nearby auto wrecker that lets you pull parts off vehicles and grab whatever is missing.
  3. Mendel Leisk
    42,028
    Yeah you’re missing something.
    Does the black bit unscrew? Maybe the light grey bit has fallen down behind?
  4. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Bad timing for this problem. With the high cost of gas, thieves where I live are starting to siphon gas from cars.
  5. PosauneGuy
    PosauneGuy Member
    123
    91
    California, here I come...
    2025 Prius
    Maybe someone already tried! And broke the pin in the process!
  6. 3PriusMike
    3,101
    2,419
    Silicon Valley
    The obvious answer is that your car is asking to be fed more.
    It craves the taste of high priced fuel.
    Mike
  7. UnceremoniousEnd
    Here
    It rotates, but it does not unscrew per se. Do you know what part this is? Is this something I can order and replace myself without too much trouble? Or is this something an auto mechanic should fix for me?
  8. ASRDogman
    ASRDogman Senior Member
    7,891
    4,013
    2010 toyota Prius Fuel Filler Door Release Cable. TANK, Body, TUBE - 7703506090 - Genuine toyota Part
    2010-2015 Toyota Prius Fuel Gas Cap Lid Door Release Cable Line Wire 77035-47050 | eBay
    Toyota Prius Fuel Lid Door Release Cable w/ Lever 2010 OEM | eBay
    2010-2015 Toyota Prius Fuel Gas Release Cable 77035-47050 OEM | eBay
  9. UnceremoniousEnd
    Here
    Thank you for the links to the parts. How difficult is this to install? Is it something that most people without much car knowledge can fix themselves? Or should I take it to an auto mechanic to get it installed?
  10. ASRDogman
    7,891
    4,013
    Check youtube. It should be fairly easy. All the panels pop off..
