Fuel Economy Drop After Speed Sensor Replacement
Discussion in 'Gen 3 Prius Fuel Economy' started by Purrius, Feb 16, 2025.
  1. rjparker
    rjparker Tu Humilde Sirviente
    11,104
    6,967
    Texas Hill Country
    They may mean the tsb no longer gets the part free. Your car is past the time limit.
    I would contact them again with the tsb link pointing out the newer part is 04002-33347 replacing the 140 part. If they don't agree then go with their advice or check another dealer.
    HOWEVER, your local dealer quote listed part number 04002-33447 instead. SO BE SURE YOUR ONLINE DEALER IS BASING THEIR NUMBER ON YOUR VIN.
    That tsb also says the installation requires the installer to "Reprogram the Skid Control ECU" (part of the brake booster). It also gives the "Calibration ID" (software version) based on the old Calibration ID. Be sure your installer knows this and has the new version of Techstream.
    #41 rjparker, Nov 26, 2025
  2. Purrius
    Purrius Member
    172
    50
    Northeastern US
    Alright folks, I have an update!
    With huge help from y'all (especially RJParker!) I got the brake master cylinder during Toyota's Black Friday sale for under $500 shipped. I had it installed by a local place for $300 on Jan 2nd.
    So far so good, I'll try to give a more substantial update once I see how she behaves for the next weeks!
    Thanks again everyone!:notworthy:
  3. rjparker
    11,104
    6,967
    Texas Hill Country
    A very good deal
  4. Purrius
    Purrius Member
    172
    50
    Northeastern US
    I'm having the same issues again (Park on a flat surface, check hybrid system, etc), it started a weekish ago.
    Here's an attached video when it did this again and I brought it to the shop.
    The mechanic said that at the front driver's side speed sensor might be shot. He said it looked pretty rowdy, and he cleaned it. He suggested if it acts up again to just replace it, and I could save money if I felt comfortable doing it myself.
    He checked the hybrid and 12v batteries as well, both are good.
    Yesterday the same issue happened when I tried using cruise control (CC) on the highway. It shut CC off on it's own, tripped the dash lights, and the CC light was rapidly flashed on and off. (It was similar to the attached video.)
    I pulled over and ran my lite OBDII reader, which did specifically identify the speed sensor (among the same codes as previously).
    Later it began making this humming sound when I'd used the brake.
    The driver's side headlight also burned out duing my car's tantrum. My gut says there's an electrical gremlin somewhere. But where to even begin? :confused:
  5. rjparker
    11,104
    6,967
    Texas Hill Country
    You go to your shop and have them change the speed sensor.
  6. Purrius
    Purrius Member
    172
    50
    Northeastern US
    Things have been very very busy, I'm hesitant to celebrate prematurely, but I do have good news.
    A couple months ago I had a brand new (and warranteed) speed sensor installed, the issues haven't returned as of now.
    The system still appears to be "relearning" fuel economy estimates, but the numbers are getting more accurate. My milage has demonstrably improved though.
