Fuel economy indication change technology
Discussion in 'Gen 4 Prius Technical Discussion' started by PRIUS MAX, Mar 1, 2017.
  1. PRIUS MAX
    PRIUS MAX New Member
    KOREA
    Hello Everyone.
    I am the owner of Prius 4th generation in Korea
    My PRIUS 4th has fuel consumption display L/100km [​IMG]
    Other PRIUS 4th has fuel consumption display km/L[​IMG]
    My prius is an early version and the other car is a recent version
    Is it technically upgradeable to use both or change??
    Is there a software or hardware upgrade method?
    Waiting for your help
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    To change the various displays of distance/mpg you need to press the Trip button on you steering wheel. If I remember right, the are 4 different sequential displays. Don't do this while you're driving as it might be a dangerous distraction. Good luck and enjoy your new Prius.:)
  3. Prodigyplace
    12,710
    11,848
    Central Virginia
    Both pictures are the "from the flag" trip. That is, starting from the latest Ready mode.
    The user wants to change the units displayed. I know the US can now switch from mpg to metric but the early 2016 could not. Perhaps somebody in Europe or @Tideland Prius might know. I am on the road and unable to help in the research. It should be documented in the owners manual.
    RCO likes this.
  4. Tideland Prius
    16,674
    There might be an option in the "Settings" menu.
    1. Using the right hand side steering wheel control
    2. Scroll left or right until you select the "Settings" display.
    3. On the "Settings" screen, press the up or down arrow on the steering wheel switch to select the item. Press the centre button to acknowledge.
    Perhaps there is a setting in that list to change the units of measurement from "km/L" to "L/100km".
    For American and Canadian cars, this is where we go to change the speedometer between "km/h" and "mph".
    Chariot and RCO like this.
  5. PRIUS MAX
    KOREA
    There is no setting menu in Korea model..:cry::cry::cry::cry::cry::):LOL::notworthy:T.T
    pilotgrrl likes this.
  6. Mendel Leisk
    42,293
    AFAIK the only thing that can change is the speed indication. If you've got mpg display, or liters per 100 kilometer, that can't change.
  7. jae hoon
    jae hoon New Member
    Colima, Mexico
    Here in Mexico. Prius 4th generation Base trim same thing, can't change X lt/100kms for X kms/lt. Only switch metric or imperial measure units.
  8. Mendel Leisk
    42,293
    Speedometer units? That would be the usual.
  9. jae hoon
    jae hoon New Member
    Colima, Mexico
    Yes, it does. Have to change it from touch panel setting in ”Display”
    Sorry for sooooooo late reply. Lot of working for Q1 closing.
    BlackBerry Priv
  10. Mendel Leisk
    42,293
    Sorry, didn't word my last post that well. What I meant to say is that typically only the speedometer can be changed, between mph and kph. Fuel consumption stays in whatever it has, the predominant system for a particular country. For example, our's is metric, and I can change the speedo only, to mph, if driving in the 'States.
    FWIW, some early 2016's in the 'States were not capable of switching speedo to metric kmh, an oversight I think.
  11. Tideland Prius
    16,674
    Yeah I'm under the impression that only the speedo can be changed (if available) since it's the most critical unit. The others are based on the country's standard units of measurements.
  12. Prodigyplace
    12,710
    11,848
    Central Virginia
    So a US Prius in Canada would show km/h and mpg?
  13. Mendel Leisk
    42,293
    Yes.
    RCO likes this.
  14. djSyndrome
    djSyndrome Member
    30
    27
    Seattle-ish
    US Prius will show metric for speed, odometer and consumption. Temperature is still in Fahrenheit, though :)
    RCO likes this.
  15. Mendel Leisk
    42,293
    Hmm, maybe fourth gen. Odometer, really?
    RCO likes this.
  16. djSyndrome
    djSyndrome Member
    30
    27
    Seattle-ish
    Yeah, mine is a May 2016 build. Not shown in this photo, but total odo is also metric.
    I'm just happy that it's easily switchable when we drive up to Vancouver. The missus' Outback is buried in a settings menu that's only available while stopped.
  17. Tideland Prius
    16,674
    What? That's interesting. In the Gen 2/3, it's just the speedo (and DRCC if equipped).
    Also, on the Gen 2/3 on the dashboard.
  18. Prodigyplace
    12,710
    11,848
    Central Virginia
    Doesn't your wife's Gen 4 change to miles for when she visits us?
  19. Tideland Prius
    16,674
    No. It was an early edition :mad:
  20. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    Here's the picture of my March, 2016 built Three U.S. model. It can't be switched between mph and km/h.
    RCO likes this.
