Fuel Filling Problem
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by eric1234, Feb 6, 2017.
  1. Prodigyplace
    12,715
    11,848
    Central Virginia
    Thanks.
    Actually, I just finished fixing mine after it ran away this spring and found a tree.:mad: Needed to replace the generator, radiator, and a woodruff key in the steering box.
    I had to argue with my grown son that I needed a generator, not an alternator. I told you the design is old. Voltage regulator, carburetor, coil, distributor points. It's all in there.
    RCO and jerrymildred like this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    LOL, ah yes I remember those well
  3. Prodigyplace
    12,715
    11,848
    Central Virginia
    This is mine in April.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Who put that stupid tree there??!! :eek: :LOL:
    Prodigyplace likes this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Ah a Generator, what we Brits call a Dynamo.
    RCO likes this.
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Oh, not what Moscow call their football (soccer) team! :ROFLMAO:
  7. Tande
    Tande Active Member
    556
    339
    Mich.
  8. eluo
    eluo Member
    123
    71
    Commack, NY
    I stand corrected... I searched online and many recommended rinsing with water to dilute the spilled gas. And if water is not available, get a paper towel and soak it in the squeegee water and squeeze it out over the spill several times. Wash and wax when you get home.
    knockknock_2 likes this.
  9. Mendel Leisk
    42,349
    I'll wager near everybody uses the sponge side of the windshield washer brush... :whistle:
    The downside to any action rinsing off the car: is gas washing into storm sewers, which often ends up in nearby streams.
    #69 Mendel Leisk, Sep 6, 2018
  10. Rondan
    Rondan New Member
    Newbury Park, Ca
    Thank you for your post. I’ve been experiencing this problem with my 2016 Prius since I bought it several years ago. I’m looking forward to seeing if this is the cause, and solution, to a problem that I’ve been getting the run around about from Toyota and my local dealership for years! Thank you again to all of you who have posted info on a problem, “that we’ve never heard of before”!
  11. Prodigyplace
    12,715
    11,848
    Central Virginia
    There was a (recall? TSB?) to replace a weak fuel door spring on some cars.
    TSB Fuel Filling Problem | PriusChat
  12. Samuel Hiponia
    Samuel Hiponia Junior Member
    I have a 2015 Prius 2 which supposed to have a redesigned fuel tank but still filling gas has always been a problem. Got to fill her up slowly, otherwise fuel would spill. I’ve done all that has been recommended but nothing works. I guess I got to live with it until this flaw is corrected.
  13. Mendel Leisk
    42,349
    2015 is last year of 3rd gen, a gen with little or no gas tank filling problems?
  14. Prodigyplace
    12,715
    11,848
    Central Virginia
    Definitely totally different than the system discussed in this thread.
  15. Samuel Hiponia
    Thanks. Tried that trick on my 2015 Prius but it didn’t help.
  16. Prodigyplace
    12,715
    11,848
    Central Virginia
    That is because you have a Gen 3 Prius not a Gen 4. They described a Gen 4 issue.
  17. Ralph Vigil
    Ralph Vigil Junior Member
    Albuquerque
    I’m experiencing this problem with my 2019 Prius LE. I’m wondering if there’s other 2019 owners that are experiencing this problem. Next time my feel I’m going to make sure to open my fuel door all the way and not touch the fuel door latch.
