Fuel filter change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sajjad Siddique, Mar 2, 2013.
  1. Patrick Wong
    18,210
    6,517
    If your car is a North American Prius, see my post #8 above. It is not possible to separately replace the fuel pump; the entire fuel tank must be replaced (not just removed.) If your car was produced for other markets, then the fuel pump is separately replaceable.
  2. Classic Car Guy
    Classic Car Guy Active Member
    502
    135
    Northwest, USA
    Thread Resurrection...
    So on a 2007, I dont need to worry about the fuel filter. Its a north american car.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    Yep, it works until it don't.
    Haven't had to do much of anything on a Prius regarding the fuel system. Have done a few tank assemblies on Gen2's, usually for a faulty level sensor. Had one where rust caused a small evap "leak" around the fuel line connection flange.
    05_silver likes this.
  4. Gloria&Suzanne
    Gloria&Suzanne Junior Member
    81
    Sacramento, CA
    Do not wait for the check engine light if you want to do preventative maintenance.
  5. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    Even though you're replying in an old thread, I'll point out that as mentioned upthread, the fuel filter and fuel pump are not serviceable in the US model Gen 2. Given that the entire fuel tank has to be replaced to service either of those, you would want to be 100% sure that they were faulty.
  6. saneesh8
    saneesh8 Member
    238
    57
    Allen, TX
    With good quality fuel, i guess it never needs replacement. I had to replace it on my bmw z3 and VW Passat. The bmw was cutting out at high rpm, Passat, i just change it as pm. Both cars, it was easily accessible from under the car.
    For some reasons, Honda and Toyota, it is a part of the pump which makes hard to do. German cars, it is kind of easy.
