Fuel gauge display problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jackmccullough, Feb 11, 2016.
  1. jackmccullough
    jackmccullough Junior Member
    45
    Montpelier, Vt.
    Not the usual.
    I stopped on my way home to get gas tonight when the gauge was showing one pip. Naturally it wasn't low, but I'm used to that.
    The odd thing is that after I got in the car and turned it back on the gauge stayed at one pip and the fuel display on the multi-function display didn't reset.
    I'll check again in the morning, but do you have any thoughts?
    TIA.
    Jack
    52,396
    have you owned it since new? i think i've read that there's a way to reset the gauge.
  3. Patrick Wong
    18,210
    6,514
    How many gallons of fuel did you purchase? If fewer than four gallons, the fuel gauge system may not recognize the added fuel.
    You could try disconnecting the 12V battery for a few minutes, which would force the fuel gauge system to reset after the battery is reconnected and the Prius is made READY or IG-ON.
    If the fuel gauge continues to read abnormally then it may need to be reset in a more systemic way:
    Fuel Gauge Calibration Instructions | PriusChat
    m.wynn likes this.
