Fuel Gauge is getting worse
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bill Parlatore, Jun 30, 2018.
  1. Bill Parlatore
    Bill Parlatore New Member
    Annapolis, MD
    Our 2008 Prius has always had an issue indicating we need to add fuel but it has never takes what we assume is a full tank of gas. The dealer says there is no problem with our car and so did nothing while it was under warranty. I never recall ever putting more than 8 gallons in it, even when new.
    Now when it indicates one or two bars it only takes maybe 5 gallons. Recently, when we drive into town beginning with three or four bars, after maybe 12 miles the fuel gauge beeps and shows a blinking one bar... after 12 miles. Today it happened again, and the supposedly on-reserve tank (with its blinking one light) would only accept 4.1 gallons after 168 miles on that tank.
    Does anyone know what the problem could be? It is ridiculous to have a car with this potential range yet we ALWAYS have to fill up under 200 miles as we don't know which gauge to believe, the fuel gauge or the total miles driven since the last reset. I would feel pretty silly having the car shut down because the blinking light was either accurate or some internal electronic switch used its input to shut things down.
    And to make matters worse, many gas pump nozzles shut off almost immediately when I try to put gas in the car, causing me to have to go to another gas station.
    Very frustrating. Thanks for any ideas.
    #1 Bill Parlatore, Jun 30, 2018
    Peter Larsen and bisco like this.
  2. Tideland Prius
    16,196
    The gas tank has a rubber bladder inside (for emissions reasons). It's possible that the rubber bladder is wearing out. I know on our 2005 Prius, the range shrunk (not as bad as you're describing) but we did notice that the amount of fuel we could put in was less than when it was new (and we could never put the actual rated amount since the rubber bladder isn't exactly the same shape as the gas tank).
    Peter Larsen and Raytheeagle like this.
    49,708
    try opening the cap and letting it breathe for a few minutes before pumping. pump as slowly as possible, and try spinning the nozzle to 90 and 180 degrees.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Another trick mentioned here by another member was to do consecutive fillips of the small amounts to help “re-expand” the bladder.
    Peter Larsen likes this.
