Fuel gauge not accurate
Discussion in 'Gen 2 Prius Technical Discussion' started by Hakam, Jul 31, 2022.
  1. Hakam
    Hakam Junior Member
    Jordan, Amman
    So i noticed when i fill in small amounts of fuel, the gauge doesn't goes up unless I fill it up to the full or if i reset the 12v battery. Another thing i am facing which is that my gas tank capacity is 30 liters max, this is if i filled gas when the last pip starts blinking. What could be the reason for that?
  2. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    This is correct. You need to add a minimum of 12 L in order for the gauge to recognise more fuel has been added.
    From which market is your car sourced?
  3. Hakam
    Hakam Junior Member
    Jordan, Amman
    I am honestly not sure. But does it make a difference? Do you mean that this is normal for some priuses?
  4. dolj
    dolj Senior Member
    8,645
    4,395
    It could make a difference if the car came from North America versus Europe. It can be usual in some Prii, but not necessarily normal.
  5. bisco
    52,850
    should take around 10 gallons iirc. might be an evap issue, hard to say without codes.
    n/a got a rubber bladder which can sometimes foul the whole filling procedure.
    keep in mind, when the last pip blinks, there's still a couple gallons left.
    how much is petrol there?
  6. Hakam
    Hakam Junior Member
    Jordan, Amman
    1.5$ us dollars for each liter
  7. bisco
    52,850
    wow, more than i expected!
  8. Hakam
    Hakam Junior Member
    Jordan, Amman
    Yes, fuel here is alot expensive
  9. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    About the same price in parts of California thanks to Joe.
