Fuel gauge reads prematurely empty
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mountweasel64, Feb 1, 2024.
  1. MountWeasel
    MountWeasel Junior Member
    30
    North Texas
    It's certainly possible. I installed a larger capacitor to avoid having the same problem a few years down the road, and this additional capacitance could have the unintended consequence of throwing off the fuel gauge. If that's the case, I believe that I could add some resistance to the level signal and make it read much closer. Too bad that I took a wrecked Gen2 Prius to the metal recycler a few months back. I could have pulled the tank had a level sensor to experiment with.
    52,774
    Might be worth pursuing the wiring schematics to see if there’s a connection between the combo meter and the fuel gauge
  3. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    You need to check all connections on the CM. There is one connection that is connected to another connector by a ribbon cable and you disconnect one end of that at the CM end. It sometimes comes loose at the other end, but you don't think to check it because you didn't intentionally disconnect it. Make sure you check that one in particular.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    Or you could pop the rear seat base out and test the sender resistance when the gauge is (prematurely) reading empty. I would expect that yours is much higher than the 110 ohm spec for "empty".
  5. Mountweasel64
    Mountweasel64 Junior Member
    Bridgeport TX
    I read that I should replace the capacitor with a higher uF unit to avoid the problem in the future, so that’s what I did. The higher value capacitor might have caused the instrument bus voltage to be somewhat higher than normal, and had the side effect of making the fuel gauge read wonky. That Chips has the same experience could be confirmation, or could be coincidence.
  6. Pioneerscot
    Pioneerscot Junior Member
    78
    Nevada
    I repaired mine with the higher ( double capacitance ) with no ill effect. I agree with checking the small connectors on the combo meter
