Fuel injector cleaner . . . WOW!
Discussion in 'Gen 2 Prius Fuel Economy' started by Sufferin' Prius Envy, Oct 9, 2006.
  1. Politburo
    Politburo Active Member
    971
    208
    Re: Fuel injector cleaner . . . WOW!
    Ethanol doesn't play nicely with the pipelines and is added in at the distribution terminal. It's certainly possible that a batch got screwed up, but having done a little work for these terminals, I'd be very surprised to see it off by that much... that's potentially a multi-million dollar mistake.
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I have been told that Shell provides Costco their gas? Hal
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    My money is on the cheapest supplier that meets Costco's requirements.
  4. richard schumacher
    7,680
    1,059
    United States
    If you use E10 the injectors are already getting plenty of cleaner.
  5. gust242
    gust242 New Member
    23
    hobart IN
    Hello
    All what about a oil based cleaner like Lucas ? and any feed back on oil additives ? I have a while to go before im broken in but im looking into the future .
    thanks Jay
  6. hobba
    hobba New Member
    85
    Estero, FL
    I just had my 2005 in to the dealer for service. They recommend cleaning the fuel injectors every 15,000 miles due to the ethanol in gas. I had them do it and I noticed an immediate increase in power and acceleration on the car. Still on the same tank of gas, so haven't noticed any change in mileage. The vehicle has 45,600 miles on it. The charge for the service was 85.00 in SWFL.
  7. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
  8. Bob.H
    Bob.H Junior Member
    38
    Findlay, Ohio
    We have 39000 miles on our Prius and I thought I would give the Chevron Pro-Guard a try on our 220 mile trip from PA to OH. On the same roads taken many times and never received more than 47 MPG but this time was 51.
    We had poor weather, 32 degrees when we started out, more traffic than expected, school buses, and a few times totally stopped for road construction. I was expecting poorer mileage with all the road conditions we dealt with.
    So I am going to give the Chevron Pro-Guard Fuel Injector Cleaner a thumbs up and will try it again.
    Bob
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Did you check wind direction and speed?
    Tbkilb01 likes this.
  10. richard schumacher
    7,680
    1,059
    United States
    Why? You're going out of your way to avoid routine injector cleaning but adding cleaner by the bottle. That's superstition. (E85 should not be used in anything but flexfuel vehicles, which Prius is not. E10 is perfectly fine.)
  11. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Re: Fuel injector cleaner . . . WOW! . . . er, maybe not.
    I've always wondered if the injector cleaner itself might not raise the
    average level of BTUs/gal. in the tank (or some other measure of energy
    density) and produce a short term, single tank MPG increase. Which
    would tend to encourage its repeated use whether or not there is any
    actual injector cleaning happening. :confused:
    If such were the case, any long term effect on MPGs would have to be
    judged/calculated on the second and following tanks of gas.
    Haven't the slightest idea how to resolve this conundrum. :noidea:
  12. 5prius5
    5prius5 Junior Member
    Schaumburg, IL
    Thanks for the info, I need to do this. My 05 prius just dropped from 45 MPG to about 36-37. Any other tips?
  13. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Cold and snow on the road?
    Do you still have the original 12 volt battery? A bad battery will cause the Prius ICE to run overtime trying to charge it.
  14. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Concur with both of the above. I currently see that in Fairfax, VA, it's 41 F and on 10/29, it was a high of 39 F and 33 F for a low. On 10/10, it was 81 F for high and 49 F for a low, in comparison.
    5prius5:
    Please answer http://priuschat.com/forums/gen-ii-...-answer-these-questions-esp-if-youre-new.html in a new thread.
    http://priuschat.com/forums/gen-ii-prius-fuel-economy/99504-why-mileage-gets-worse-in-winter.html
  15. dhanson865
    851
    188
    TN, USA
    I didn't say I was adding cleaner by the bottle. I just said I wasn't buying E10.
    You can see more on that topic in http://priuschat.com/forums/gen-iii-2010-prius-main-forum/98236-there-recommended-gas-prius.html
  16. 5prius5
    Schaumburg, IL
    Thanks I just did :)
    I will check the battery status and add that as well to rule that out.
  17. richard schumacher
    7,680
    1,059
    United States
  18. abelincoln1979
    abelincoln1979 New Member
    FL
    Has anybody tried STP Super Concentrated Fuel Injector Cleaner?
  19. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Good ole STP! (y)
    Used it in the 70's in my first car...
    A 1954 CHEVY, I always belived it helped, till I bought a new engine. :confused:
  20. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    In some sense, fuel system cleaner with high amount of PEA such as Redline, 3M, STP deep clean, or BASF KeropurG may help cleaning injector, intake valves, and piston tops. However, most of Prius engine are generally already clean not like direct injected engine in VW, Hyundai, or Ford. In direct injected engines, the effect are usually higher since the injectors get dirty faster than port injectors. For a good test. People should do fair test of 2000 miles before and after with the same temperatures, speed, travel area, and distance. I can guarantee, it will only make minor difference if you already used TopTier gas stations like Chevron, Shell, BP, Total, Costco, etc. In my opinion, it is cheaper by using Shell gas station with membership bonus than for instance Walmart + fuel additives every 3 months.
    In facts, Toyota recommends fuel system cleaner annually by just adding it to the tanks. Especially Canada and cold zone. In Europe, Toyota Prius use midgrade Fuel/Super 89 instead of Regular 87 and usually with E5 instead of E10 10% ethanol. I personally got about 1-3% higher gas mileage in Europe with my prius 3rd gen then when I was in USA at similar terrain/flat. Here, BASF KeropurG is cheaper than Redline, STP, etc. I put it every year before oil change / 10k Miles. Don't feel much different because I used Total, Aral/BP, or Shell all the time with E5 Super instead of E10. With E10, I lost about 2% because of small engine. In bigger engine like camry or RAV4, the difference between 5 and 10% ethanol are less. E10 is still cheaper about 3-4% but I prefers E5 for longer terms reason, longer life of catalytic converters and better low-end rpm torque/power.
