fuel injector cleaning?
Discussion in 'Gen 2 Prius Technical Discussion' started by smtrader, Jun 29, 2007.
  1. tam85
    tam85 New Member
    16
    illinois
    I
    hey, thanks for this info..
  2. Macs
    Macs Junior Member
    NY
    I see a couple of members mention Techron. Is is a superior/highly effective fuel/injector cleaner?
  3. Macs
    Macs Junior Member
    NY
    Always check the oil, even if Toyota changed it. I once had a case where the dealership overfilled my oil. Because it was clear, I thought something was wrong with my dipstick, until 6 months later as the oil got brown, I was convinced they had over filled it.
  4. Macs
    Macs Junior Member
    NY
    P0301 means a misfire in cylinder #1, as your probably know. Did the engine lose power/compression and what was the solution?
  5. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    @Macs, I notice you are a new member so welcome to Priuschat.
    Just pointing out that this is a 10-year old Gen 2 thread and some of those people haven't posted in 10 years? It may pay to check dates before posting to make sure a post is still relevant.
    Don't forget to check out Gen 3 threads too.
  6. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    I don't know if fuel injector cleaner helps or not. I just use Top Tier fuel and figure it's good enough.
  7. ChapmanF
    19,019
    It seems that the stuff in Top Tier fuel is pretty good.
    I've heard good things about Techron, it probably does something.
    We also have some evidence that if the injectors are bad enough to cause noticeable engine symptoms, they might be beyond help by an in-tank additive, but a bench cleaning works great.
  8. Macs
    Macs Junior Member
    NY
    Thanks, Dolj. I don't know how to start a thread, or post something. I have a problem about engine misfire and rattling on a 2010.
  9. dolj
    dolj Senior Member
    8,645
    4,395
    Go to the Gen 3 forum in which you want post a new thread, look for the "Post New Thread" button at the top right (see image)
    Choose a title and then start your post.
    I hope this helps.
