Fuel injector repair
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gloria&Suzanne, Jul 19, 2026.
  1. Gloria&Suzanne
    Gloria&Suzanne Junior Member
    81
    Sacramento, CA
    The rubber seals are getting worn and the pintle caps are cracked/missing. The first time around, I did not know that there's a way to prevent gasoline from oozing out of the rail during the job, which I caught the leaks with shop paper towels. When I reassembled them after cleaning them and the ports out, the engine ran smooth at idle, but I immediately noticed a gasoline odor. I realized it was because I seated them too loose. I overcorrected this by tightening to 20ft/lbs and put small, thin metric universal rubber O-rings at the base of the nozzles to get them to seat then tight enough that they couldn't move. I was doing this in an attempt to do a temporary fix until the fuel injector parts would arrive, and I'm worried I may have ended up damaging some of the pigtail connector metal prongs in the process of struggling to unplug them, even when pressing on the tabs. When I reassembled it and did a test run, it loudly misfired the moment the engine came on, so I turned the engine off immediately. What was my most likely mistake? Can even something as seemingly trivial as small O-rings on top of the cylinder port grommets cause such a bad misfire?
  2. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    I doubt you're misfire is caused by the o-rings it may be caused by the leak past the o ring big looking atctailmwen it's live and pressurized you may see the leak. When the injectors are fitted to the rail and the spacers are applied under the bolts in the rail tabs and tightened . The fuel injector should be able to spin by your two fingers .
  3. ChapmanF
    19,033
    The only things I'm thinking you could have been "tightening to 20ft/lbs" would be the bolts that hold the fuel rail to the head. Because the rail sits on solid spacers beneath those bolts, overtightening them (once the rail is all the way down on the spacers) doesn't really affect the injectors at all. They're sitting there snug in their little O rings and all you've made different is a couple overtightened bolts.
    For the seal to be good, the grommets and O rings just have to be good, and carefully not damaged when reinstalled to the rail:
    There has been at least one old thread here where someone did not get the O ring ends of the injectors quite properly inserted into the rail (as in the drawings above), and then thought they would simply be pushed in the rest of the way as he tightened down the fuel rail bolts. That led to at least one injector being crushed and needing replacement.
    It's possible that adding something to the grommet beneath the injector, raising its height, could lead to a similar result, but I haven't seen your situation so it's hard to say.
  4. Gloria&Suzanne
    81
    Sacramento, CA
    I did not smell any gasoline and even a small amount of gasoline can be easy for the nose to detect.
    It's okay for it to be able to spin while in place? I must've overtightened it with the O-rings then. Three electric connectors wouldn't snap in all the way. If the misfire persists after I fix my mistakes, then, it will be time to call in the pros, so I'll have it towed to the mechanic.
  5. Gloria&Suzanne
    81
    Sacramento, CA
    And an extra O-ring that wasn't supposed to be there.
  6. ChapmanF
    19,033
    As you saw in the repair-manual drawings I pasted above, it's not only okay, it's a necessary post-assembly test to make sure you've done it right. :)
    (Well, I guess I didn't paste anything that says it's still twistable after the rail is installed, but it generally is.)
  7. Gloria&Suzanne
    81
    Sacramento, CA
    I th
    Yeah,
  8. Gloria&Suzanne
    81
    Sacramento, CA
    The misfire was bad enough I turned the car off immediately. N
    Aha. I think the misfire was caused by air still being in the fuel rail, since I depressurized the fuel system first
  9. Gloria&Suzanne
    81
    Sacramento, CA
    And didn't repressurize it before allowing the engine to start.
  10. Gloria&Suzanne
    81
    Sacramento, CA
    2013 Toyota Prius
    After putting the fuel injectors back in, The Prius misfiredjp loudly and violently immediately when the engine started running after the "temporary" fuel injector fix which I immediately shut the engine off.
    I thought hard for a few days about what might have caused it. I had an idea. Since I depressurized the fuel system first to avoid a hazardous gasoline mess, and didn't re-pressure it before allowing the engine to start, so fuel hasn't yet reached the rail before the engine started. Since there was still air inside of the fuel rail, this may have caused conditions to be far too lean in terms of air/fuel ratio. I think this was the most likely reason for the misfire. That would make a whole lot of sense.
  11. ChapmanF
    19,033
    That sounds plausible.
    I might only add that I'm a person who likes to test things after doing work on the engine and before starting it up. Therefore, I am likely to put the car IG ON without engine start, and use a scan tool or jumper wire to run the fuel pump and pressurize the rail while I look over all the work I just did for any leaks. Then I'll use a 9-volt battery to tickle the terminals of each injector and listen for the click and sound of squirting. The first one might at first sound more like spitting for a moment at first as air in the line escapes. If I start with the injector at the distal end of the fuel rail, the other three will pretty much immediately squirt fuel when I get to them.
    If the test-squirting is overdone, of course, it could lead to a hard first start because of flooding. Hasn't really happened to me, but I tend not to just move on to starting the engine right away. I might putter some, put the wipers back on, put tools away, and such, and by the time I get around to starting the engine it doesn't act flooded.
    The idea of a 9-volt battery to manually tickle injectors is courtesy of Rich Jensen of Cruzin Performance, who was doing the restoration of injectors in our PriusChat restored-injector exchange loop, back when we were doing that. 9 volts is still enough to test the injector, but low enough to lower the risk of damaging it when applied by hand (the pulses the ECU uses are much shorter than what a human can do).
  12. Gloria&Suzanne
    81
    Sacramento, CA
    The issue was I hadn't given the fuel system enough time to repressurize, so there was still air filling in the space in the fuel rail, creating extremely lean conditions.
  13. ChapmanF
    19,033
    I wouldn't lean too hard on the "enough time to repressurize" angle, though. I was going to guess the answer as "easily under one second" from first application of fuel pump power, and this AI chat showing the work came out in the same ballpark:
    https://share.google/aimode/H9QQw6ewd10dhyGvp
