Fuel Mileage Doesn't Reset
Discussion in 'Gen 2 Prius Fuel Economy' started by jstern, Dec 22, 2005.
  1. jstern
    jstern New Member
    Peekskill, NY
    Just got a 05 Prius about a month ago. After first fuel refilling, the fuel mileage reset back to zero (as I believe it is supposed to). Ever since then, it doesn't reset itself after filling up the tank--I have to manually reset. While it sounds like some on this forum would like this to happen, I actually like it restting each time.
    Anyone know why mine doesn't auto reset?
    Jeff
  2. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    it doesn't reset right away. Sometimes you can drive almost a mile before it resets itself after refueling.
  3. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Also if you didn't refuel over certain amount of gallons, it won't reset. I don't have the exact number... I think it's around 3 gal?
  4. maggieddd
    2,090
    Boston
    that's right!
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    Minimum is reported to be 4 gallons.
    2 other conditions have to be met before the auto-reset occurs.
    1)Fuel guage must reach 'full'.
    2)Then the wheel must turn one full revolution.
    So, if you fill up, pull away, stop at the light to merge into traffic it's likely the guage won't reset.....until you pull away. But then the guage will have registered 'full', then it's just waiting for you to roll again.
    Interestingly, I 'filled' a few tanks ago to what I thought was full (added about 8 gallons), but had pump problems. the guage registered to 9 out of 10 "pips". But I went through the little 'no touch' car wash at the gas station so sat idle for a long time after the guage got to the 9 pip level.
    Then I pulled away and the guage did not ever reset....even after driving about 15 miles. Don't know if it was b/c the guage didn't show completely full or b/c of the long idle time without moving.
  6. canuckican
    canuckican New Member
    75
    Windsor, Ontario, Canada
    Yet another Prius fuel-tank/gas-gauge idiosyncrasy! There are plenty, aren't there? Toyota really did some crazy, fairly non-standard things with their fuel system on this car, I think we would all have to admit, wouldn't we? Once you learn to deal with it, it's no big deal, though.
  7. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Doc, I think condition 1) doesn't have to occur. I remember one time I refuel a decent amount (~5 to 6 gal? not too sure) but not full. The gauge did reset afterward. But I could be wrong, it's all from memory.
  8. aaf709
    3,862
    2022 Prius Prime
    It can take a while. The station where I normally fill up is in a large parking lot. Most of the time it has reset right when I leave. An interesting coincidence, if I didn't activate the BT in my phone, I get a BT connection failure exactly when it resets.
  9. efusco
    19,891
    1,193
    Nixa, MO
    And you could be right, I've never personally not filled up all the way. I remember my wife once accidently underfilled (early shut off of pump) and I'm pretty sure the guage automatically reset (I wasn't with her so can't be positive--but I don't think she knows how to do the reset).
    so perhaps #1 should just be changed to "Fill with minimum of 4 gallons"
  10. jstern
    jstern New Member
    Peekskill, NY
    Thanks
    I have filled up each time. Drove out of gas station each time. Don't remember about the wheel turn thing. Will have to monitor next time.
    jeff
  11. jeromep
    jeromep Member
    827
    Eastern Washington State
    Well, the wheel turn is not the steering wheel, but your vehicle's wheels.
    I will add that I have been fortunate enough to never have a really bad fillup. I've had some that were a bit shallow, however I still got all pips and the display reset as I was pulling out of the gas station.
  12. luvmyhybrid
    luvmyhybrid Junior Member
    Does anyone know if it's possible to view the total MPG for say the life of the vehicle on the MFD?
  13. LtRipley36706
    LtRipley36706 New Member
    16
    Nashville, TN USA
    I, too, would like to know if its possible to get a lifetime MPG readout.. Is this possible in the 2006 Prius? =)
  14. Frank Hudon
    Frank Hudon Senior Member
    4,147
    simple answer=no. long answer=only from your spreadsheet. really long answer only in the Classic Prius was there a lifetime total. It rolls at 9999mile/km but the total mpg/liter per hundred kms. stays as it was.
