fuel pump? code #3190
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DMil, Jun 19, 2023.
  1. DMil
    DMil New Member
    Austin, Tx
    Was idling in my driveway to work on the AC, shut down, took the gauges inside, started, drove 2 blocks and red triangle of death lit up and the car coasted to a stop. Traction battery showed depleted. ABS and VSC lights also on.
    Was extremely hot-102F and car had been sitting in the sun.
    I messed around for a few minutes and retried and it started right back up. Drove home, engine was boggy. Came out a bit later and it restarted and drove to the grocery store just fine.
    Code was just #3190- poor throttle response.
    The way it went out and came back says fuel pump to me. However, the fuel pump appears impossible to replace. No auto parts store carries anything. It's not sold except as with a whole new gas tank from Toyota, over $2K in parts alone. That suggests to me that this might not be something that actually gets replaced?
    I don't know, I'm gonna check the 12V battery to make sure.
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  3. DMil
    DMil New Member
    Austin, Tx
    Hmm I checked the 12V battery. Normal resting voltage is 12.6V, and it's super hot out now- which raises the normal resting voltage of an agm battery higher.
    I got 12.2V. That's suspect. When it died, I did see the VSC and ABS lights come on too. That's a bit questionable- I wouldn't automatically expect those to light up if the engine had no fuel pressure.
    I DO know that when this battery died a few years ago, the dash went absolutely crazy when I tried to start the car. Everything flashing on and off, even the drive position cycling through park, reverse, drive, as various pumps clicked on and off and made dramatic whining noises of varying pitch.
    The fuel pump can't be replaced except with the whole tank, and the tank set is over $2K for the part alone. Nope, not something you can lift the rear seat and pull out, not in Gen2 apparently.
    The starting battery is over $250, and was replaced only a few years ago, but it is in Texas heat, with the "extra" ABS/VSC lights when it died, and seeing only 12.2V on it now- ok, yeah, I'm warming up to thinking we need to replace the starting battery first.
    This may also somehow explain my air conditioning kicking out while driving, despite having good pressures, which showed up a few days ago. If system voltage was going low, that could cause the compressor to choke.
  4. Tombukt2
    Tombukt2 Senior Member
    13,757
    2,491
    Durham NC
    Yes it could explain a few things but if those are the cases then you should fail a load test pretty easily and that's easy test for any place that wants to sell you a battery they should show you that yours should fail a load test or fall on its face or whatever they want to call it You're 12 volt battery doesn't have to be very specialized for the Prius It doesn't do any starting duty it just needs to have 12 volts 12 6 12 2 Is above 12 volts so it should be okay but if it can't take a load it doesn't matter what the voltage is you can still have 12 volts and have no cranking amps You go to the junkyard you see this all the time put a meter on a battery it'll read 12 volts 12-1 you connect the 12 volt light bulb up to it and it barely turns orange and then turns off test the battery again and it's zero.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    No. The AC compressor in the Gen2 is driven by a 3 phase electric motor powered by...the HV battery and inverter.
    On another note, even Walmart now offers the Gen 2 Prius battery with JIC terminals. There's a thread here somewhere, where I posted photos of two of them on the shelf at a local store. NAPA also typically has one or two on the shelf.
  6. DMil
    DMil New Member
    Austin, Tx
    Well, I found the battery was under warranty, under 2 yrs old. I did put a charger on it this morning after finding 12.2V on it.
    However, I put the MFD into diagnostic mode and went driving around the neighborhood, and the battery voltage remained a solid 13.7V. I don't think this is going to be a warranty replacement.
    The 2009 Prius fuel pump (220K miles on this one) is a huge problem if that's what's wrong. Yep, it's integrated into the tank and bladder and cannot be replaced, you have to remove the whole tank. >$2000 part. Labor would be pretty high. I could do a junkyard pull, but that may be beyond my capabilities. Esp since it's over 100F outside. This could be reason to scrap the whole car rather than try to fix.
    And I don't have solid proof it was the fuel pump. It did this ONCE. It scared me because it gave zero warning. Traction battery got depleted as normal, tried to take off from a stop sign, it tried to start the engine and failed, threw the RToD, engine stopped, traction battery already drained. And with the traction battery drained, there's very limited window for diagnosis before the ECU's restart attempts make the traction batt go totally flat and create an additional crisis. Filled up the night before, it has gas. If this happened on the expressway going to work, even if it starts up fine a few minutes later, bringing the town to a standstill is pretty serious. That's most of my drive, there's nowhere to pull over for much of it.
    I don't see what to test further, if it's not misbehaving at the moment. I wouldn't be surprised if the fuel pump developed normal pressure until it drops out again. I went through the sheet SFO gave. It didn't actually throw a code for the engine failing to start, just poor throttle response, even though it quite definitely died but came right back and ran fine. So I don't think MAF is dirty, that wouldn't just stop the engine out of nowhere and then go away. Sudden stoppage then working fine keeps screaming "fuel pump" to me. Searching PriusChat for code 3190 seems to have a high correlation with fuel pump, but it looks like few people even tested that theory due to the incredibly high cost.
    It was immediately after some really unusual conditions- extreme heat, and prolonged idling while working on the AC system. But I don't see how that would explain the symptoms, nor does it seem likely I could recreate it to better troubleshoot it. The only other factor is the low battery voltage (12.2V) this morning but the battery is looking ruled out so I don't know.
    Normally I'd be out poking around more, but it's really REALLY hot out there right now. And if the fuel pump wasn't so crazy expensive and labor-intensive I would have already moved to replace it.
    I have Torque and Dr. Prius app. I don't have Techstream. Any suggestions on next steps? All I can think of is drive it until it throws the code and check the battery voltage. Or throw $50 at a Techstream reader and some $$$ for a temp subscription to Techstream.
    Taking it to a mechanic for diagnosis, is this likely to be productive? Seems like they'd do similar guesswork if the problem doesn't reoccur and likely guess fuel pump too, but fuel pump is too expensive to do based on a hunch.
    #6 DMil, Jun 19, 2023
  7. DMil
    DMil New Member
    Austin, Tx
    And is there any additional theory that I could work on that explains why the AC stopped working about the same time? I don't see how. It's blowing 35C air. When I first started it, I saw it get to 20C at the vents but then the compressor shut itself off and vent temp shot right back up. I see it start to try to restart- temp dropped for a few seconds, but only a few deg, then gives up and shot back up again. Seems coincidental. The 12V starter batt, if failing, shouldn't do that, and the 12v batt seems ruled out for now anyhow.
  8. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Well, the AC compressor is powered by the inverter. The inverter uses DC voltage/current from the HV battery and converts it to AC power to run the AC compressor. It also converts that HV battery power (using a DC to DC converter) to........about 13.7 volts to keep the 12v system charged up (kind of like a solid state alternator) so that's why you see 13.7 volts while the car is in READY condition. It has nothing to do with the 12v battery. Back to.....the inverter has a water cooling system to keep it from overheating. The inverter cooling water pump (located directly behind the driver head light) circulates the coolant in this loop. If the inverter gets too warm, it will cut power off to the AC compressor to 'save itself'. Intermittent AC is one of the early signs of a failed inverter cooling water pump. Maybe that's what is happening in your case. Plenty of info in the forum about how to test it.
  9. DMil
    DMil New Member
    Austin, Tx
    Interesting. I did have the RToD a year or so ago for inverter coolant pump failure. Replaced with OEM.
    So the ICP is new and a reliable OEM, and no code for ICP fail. I wonder if it has an unusual silent overheating fault because it was like 108F here?
    Been driving the last couple of days with no prob from the AC.
  10. Leadfoot J. McCoalroller
    8,235
    7,736
    Pennsylvania
    2018 Prius c
    The pump isn't the only component in that cooling circuit, but I think it is the only one that can trigger fault codes. (coolant itself, hoses, radiator can't, for example)
  11. ChapmanF
    18,889
    In Gen 2, I don't think the ECU has any intimate knowledge of the pump. (In Gen 3, the pump is variable-speed, and controlled a bit like the engine water pump, so the same sorts of codes can be triggered.)
    In Gen 2, I think the code you're likely to see for a pump problem will be P0A93, but really that just means inverter stuff isn't getting cooled well. I think it has a couple different INF subcodes to suggest the ECU thinks it's more likely to be a pump or a fans issue. (I'm not sure how it makes that judgment, but I think there are multiple temperature sensors in the inverter circuitry, and different causes probably mean different patterns of which ones show high.)
  12. Garage Boxwood Lightpole
    Garage Boxwood Lightpole Junior Member
    U.S.A.
    Anybody actually have specifics on how to test the fuel pressuregiven there's no valve on the line? I'm running the user manuals troubleshooting process for P3190 and my next target is fuel pressure. I suspect I may have a bad pump, too, but I wanted to be really sure before pulling a tank from the junkyard.
    I also had trouble finding which year models have compatible tanks with a 2006.
  13. rjparker
    rjparker Tu Humilde Sirviente
    10,866
    6,824
    Texas Hill Country
    You disconnect a line and secure the gauge to it. You can get a tee adapter hose to keep the system functional if you want.
  14. Tombukt2
    13,757
    2,491
    Durham NC
    05 to 09 Gen 2 tanks.
  15. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Curious what makes 2004 tanks different?
  16. Tombukt2
    13,757
    2,491
    Durham NC
    My bad 04 to 09 Gen 2 fed EPA type tank. Someone needs to look at what it would take to fit a UK tank to the Prius that gives you changeable fuel pump so on and so forth. Yesterday I was underneath my '08 and noticed that the tank is very similar to some other Toyota models without the bladder so anything in the 11 to 12 gallon range from a Yaris Corolla etc I'm sure it's fair game for being a pretty close fit tank fill hoses and feed hoses and whatnot can be flexible or crush bent or what have you. I may not get around to all these checks but yesterday it looked like it is very doable even from a tank from the USA that would give you a fuel pump a sender unit and what have you that could be dealt with when need be.
  17. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    @Rivieraman71 took quite a stab at it in this thread : Corolla to Prius gas tank swap | PriusChat
    Perhaps you can attempt something similar, even if only fitting different model tanks for clearance, then someone else might run with it.
  18. Tombukt2
    13,757
    2,491
    Durham NC
    I read part of that 12 pages of threads of the tank change The pictures involved and what not the Corolla tanks look flatter and wider from the flange to the top and the bottom of the tank is narrower so the tank has to be wider and longer if you will seems it would create a fit problem even though Prius is based on the world renowned Corolla family it's still would be better to take a tank from like a Scion XA little wagon thingy or the Yaris would seem to be similar to almost identical fit for the tank where is the Corolla You may have to do a little finagling to get it in the chassis of the Prius.
  19. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Sounds like you could be on to something, now see if either one fits (close enough), and maybe the "next guy" (or possibly @Rivieraman71 ) will keep the dream alive, then we can all share in the tank battle victory.
  20. Tombukt2
    13,757
    2,491
    Durham NC
    When I'm out at LKQ and see either one of those two cars I'll probably just grab the tanks It just takes a minute when you're at LKQ they're half out I'd like to find a plastic tank that could go in place with the square shape it should be pretty doable everybody has the pretty standard emissions connections.
    SFO likes this.
