Fuel tank issue---anyone else having it?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by simone bercu, Jul 22, 2014.
  1. simone bercu
    simone bercu New Member
    Bethesda,md
    This is my 2nd Prius with just under 40,000 miles. There was no impact or damage just the seam is opening and I am smelling gas.
    The dealer is waiting for the part.
    I did not expect that from aToyota let alone a Prius.
    Oh, it is $1,400! I am not pleased.
  2. Mike500
    Mike500 Senior Member
    2,593
    764
    I'd have the dealer contact the Toyota national representative.
    I believe that the fuel tank is part of the emission control system and has an extended warranty.
    Unless you handed directly on an object on the road on the downward stroke of the suspension and imparted an "overpressure" condition in the tank, it is a manufacturing defect.
  3. JC91006
    16,482
    8,400
    They may also cover this cost on a good will warranty if asked. Can't say I've heard of this before. This car is not salvaged right?
  4. loansum
    loansum Junior Member
    CA
    This is why I bought the extended warranty. Already, my nav unit has been replaced on the warranty. Replacement cost for the Nav unit is $2200 plus labor. Warranty cost was $2300. You've been given some good suggestions. I've heard that the dealers sometimes will do this kind of premature failure work at the warranty labor rate. This will save you some money. Ask, it can't hurt.
  5. nsfbr
    nsfbr Member
    112
    30
    Northern Virginia
    2013 Prius v wagon
    Unless you did something to damage the tank, this is on Toyota. The gas tank IS part of the emission control system. It is where emissions begin. You are Bethesda, meaning you have access to the local news media of the nation's capital. I'd be very clear with your dealer that if this isn't covered under warranty, you'd like to exactly why...so that when you explain what happened to Channel 7 you have your facts right.
    They will take care of you I'm pretty sure.
    Edit, strike what I said above. It isn't covered. I found this pdf:
    http://owners.honda.com/documentum/warranty/partslist/apl32586.pdf
    If you were someplace else it would be, but it isn't covered under the mandatory Federal warranty.
    I would still seek to have it covered as a good will item. And I'd still consider using the local media if you need to. Leaking gas in Prius...isolated incident or hidden danger on our streets, film at 11...
    #5 nsfbr, Jul 22, 2014
  6. Mike500
    2,593
    764
    Wouldn't be too hard to replace for about $400, if you do it, yourself.
    It'll take 2-3 hours. Make sure that you extinguish the pilot light on the water heater.
    Better done outside.
  7. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    This should be covered under emissions system warranty, if nothing else. I'd bring the full court press to avoid paying that bill.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    No thankfully, this is not yet a widely or commonly reported problem. And sorry but despite your unfortunate reality, I hope it doesn't become one.
    One of the big reasons I waited (and waited) and eventually got a Gen 3 Prius over what would of been a good bargain last model year Gen 2 Prius was the replacement of the Fuel Bladder with a "regular" gas tank.
    I live in Oregon a state that doesn't allow you to pump your own gas, so the idea of potential fuel fill issues that sometimes do arise with the Gen 2 fuel bladder seemed like a real potential PIA.
    BUT...I remember reading about the "new" Fuel tank in the Gen 3 Prius. If I remember correctly Toyota defined the new tank as being made out of a " light weight resin" . I remember having some concern at the time about the durability of a gas tank made out of resin.
    So no...I don't think a lot of people have reported this problem. And I hope it doesn't become a growing problem as the Gen 3 Prius age.
  9. Mike500
    2,593
    764
    Plastic fuel tanks are "blow molded" from a combination of HDPE and polyamide or Nylon, either laminated or homogenous, as the material has to meet low permeation rates to comply with EPA Regulations.
    Blow molding leaves thin places, especially at corners away form the port or channel where the air is injected. Just examine a milk jug.
    If the material cools too quickly, a defect can occur that would eventually crack from expansion and contraction of the fuel vapors pressures inside the tank.
    hybridbear likes this.
  10. The Electric Me
    9,083
    5,798
    Are you sure the Gen 3 Prius has a "plastic" fuel tank?
    I clearly remember around the time of the Gen 3 release, Toyota defining the gas tank as being made out of what they called "resin". It raised a small red flag in my head.
    Was hoping and I am hoping that this "resin" is as durable as any standard material used in manufacturing a fuel tank.
  11. Mike500
    2,593
    764
  12. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    If you are smelling gas in the car, it might be coming from this cover plate's seal being compromised. Is the odor stronger in the back seat area as the cover is under the left rear seat:
  13. simone bercu
    Bethesda,md
    No way. It was purchased new at the same dealer.
    The service person did and the answer is: "not under warranty. ". I do not give that easily.
  14. simone bercu
    Bethesda,md
    I do not know at this point they gave me a rental until the part arrives.
  15. The Electric Me
    9,083
    5,798
    Hmm...interesting.
    My guess is Toyota probably chose to refer to the tank as being made out of a light weight "resin" as opposed to saying it was a Light Weight "plastic" thinking resin sounds more environmentally friendly.
    In any case, I do hope this is not a problem that starts to arise with all Prius.
