Fuel Types for Oz Prius
Discussion in 'Gen 3 Prius Main Forum' started by SmogSlide, Feb 26, 2010.
  1. SmogSlide
    SmogSlide Member
    128
    17
    Melbourne
    In addition to the previous post, I had my 2nd service on 20k interval, which was 3k ago... no marked differences in fuel consumption.
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Hmmm, maybe. I've used 98 in other cars before and it can make a difference in some and none in others.
    I have put 98 in my Prius before and it appears to run smoother but no mpg difference.
  3. hotelcc
    hotelcc New Member
    Australia
    Hi all,
    Another Australian Prius here - was wondering if we could use standard E10 fuel here in NSW and the possible detriment vs using 95 or 98 as recommend in the manual? Read the thread already, but was wondering if anyone else has useful tips.
    Thanks in advance
    Edit: Just noticed I posted in the Gen 3 thread when mine is a Gen 2... oops
  4. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Assuming that the numbers in the manual are for the octane measuring system where you live,
    you need to use the minimum octane listed. The presence or absence of ethanol has no bearing as long as the number is right.
    There is NO advantage to using a higher octane than you need.
    There is a slight loss of energy with E10; about 4% so getting non-ethanol fuel would have a mileage advantage......but only if it costs less than 4% more.
