Fuel wrong indication
Discussion in 'Gen 3 Prius Main Forum' started by R.I, May 11, 2023.
  1. R.I
    R.I New Member
    Jordan
    I faced a problem yesterday whilst driving, the fuel indicator suddenly gave empty and the engine shut down, I managed to put over and did a hard rest to the hybrid battery as well pulling the white fuse out, then the car went back to normal, now I'm afraid it will happen again and I don't know what to look for, can any one help, most appropriated
  2. JC91006
    16,936
    8,647
    I don't know why if the car is out of gas, you would reset the hybrid battery (didn't know that was even possible). Should you just put gas in the car?
  3. Mendel Leisk
    42,343
    The gas gauge jumped back up? What level's it showing now?
  4. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    Could be related to the float sensor in the hat. They wear out over time on lots of vehicles. Does toyota have a safety feature with this? I'm fairly certain ive got 20 miles below 0 multiple times, but also when i read fuel level on my scan gauge from the x-code for Toyota it gives me the actual reading of like 1.X gallons left.
  5. Tombukt2
    Tombukt2 Senior Member
    13,858
    2,516
    Durham NC
    I go 435 mi then I'm looking for gas If I'm going to hit 4:35 and going to be knowingly out in the country I'll gas up before then other than that there's nothing to think about My phone can tell me my mileage as can other devices
  6. bisco
    52,848
    maybe a bad 12v or loose connexion
  7. R.I
    R.I New Member
    Jordan
    Just to mention, the car had more than half tank fuel, and after the power was restored, the indicator gave me the correct amount, and also I filled it up next day and what I put in confirms that it indicated the correct amount
  8. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    Could you (or someone) explain what you did? Since it saved your bacon, sounds like it would be good to know.
  9. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    Odd it should shut down, I recently had a rock bounce under the car which hit the fuel tank hard enough to dislodge the float arm off the sender unit in the tank, car ran perfect for 3 months with zero fuel showing on the gauge and light flashing.
    Pulled out sender unit and fished around in the tank for the missing float... Resembled and all good again.
  10. R.I
    R.I New Member
    Jordan
    I did the reset out of panic, the car had fuel in it and the indicator was OK after the reset and the car drove Norma
    It showed half full, but filled the car any way
    The problem has not repeated since then but I'm nervous driving that it might happen again
    #10 R.I, May 22, 2023
