Full charge is lower (8.1) in summer than winter.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PriusPlug, Aug 25, 2013.
  1. PriusPlug
    PriusPlug Junior Member
    32
    Hello Guys
    I live in NJ and in summer i am getting a full charge of 8.1 miles. In winter i used to get almost 11 miles. I thought in summer the charge will be even more?. Am i missing something?. Any body run into similar issue?.
    Thanks....
  2. Zimmy 1
    Zimmy 1 Junior Member
    61
    Smithtown NY
    This is YOU, the way you drive. You must go slow, slow starts,slow stops,etc. No A/C(when on EV) NOthing that will use electric. Charge often. The car will remember how you drive and the miles per charge will increase slowly. I live in NY and I went from 9.0 in winter to 12.5 in summer.
    49,493
    state of charge probably doesn't change to much, but estimated range does, as zimmy says. and perhaps you get better winter range because you use the ice more. trying going out everyday in your spare time for a full electric drive at slow speed (average around 20 mph) and stay close to home so you can return before ice comes on. then see what your estimated range does each day after charging.
    CaliforniaBear likes this.
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I could give you a suggestion, but each time I do, nobody is interested in trying it. Disconnecting a wire is apparentlyy too hard! But, I will agree with the previous posts.
  5. CharlesH
    2,785
    1,152
    Roseville, CA
    Are we talking here about the estimate of EV range that shows on the dashboard display, or the actual EV range determined by some other means?
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
