Full on intake, egr, throttle cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Wtfdustinwtf, Nov 30, 2023.
  1. Mendel Leisk
    42,345
    Check out the @NutzAboutBolts video for inverter coolant change. IIRC after fill you put it in ready, but just for a matter of seconds, to cycle inverter coolant pump, then shut down, before engine kicks in.
  2. Prius DIY nut
    Prius DIY nut Member
    92
    43
    Ontario, Canada
    Here is some visual aid on the both circuits coolant replacement, maybe it was already mentioned here, apology if it was.
    Mendel Leisk and bdc101 like this.
  3. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    You just fill the inverter, put the car in ready, without starting the engine and it will
    turn the inverter motor on. Then add to the fill line. But fill the engine coolant first!
    For the engine coolant. FILL IT VERY, VERY SLOWLY! Put in a cup or two, wait 10-15
    seconds, fill again. Continue like that until the coolant is at the "B" line.
    Ready the Prius, wait for the engine to run and stop on it's own. Wait 5 minutes or so and
    check where the coolant level is. I fill it just above the full line, because it's right at the
    seam for the two half's of the tank. Which is hard to read.
    Then drive ti around the block for 5-10 minutes. Park on level ground and check the next day.
    I've changed the coolant 4 or 5 times and filled like that and never hard a problem.
    #23 ASRDogman, Dec 5, 2023
  4. Mendel Leisk
    42,345
    There’s an engine coolant air release vent, white cap above EGR.
  5. bdc101
    bdc101 Member
    250
    usa
    Yes, all you should have to do is open this up and fill until you see coolant dripping out. Then close it.
  6. Wtfdustinwtf
    Wtfdustinwtf Junior Member
    45
    17
    Carolinas
    I imagine I will have a large quantity of air as I currently have disconnected most collant lines to take out egr cooler intake manifold and such. So when I get everything put back together and add coolant (for engine that is) at what point would I open this air vent? While the engine is first started up? After the thermostat opens up?
  7. Wtfdustinwtf
    45
    17
    Carolinas
    My scan tool is just a simple Bluetooth Amazon one. I know techstream is toyotas go to system but currently I just car scanner app. Are there any mobile friendly apps that allow one to manually turn settings on? There is a coding feature on the car scanner app in theory if I have toyotas code I can change it to on but this would require more time than I'd like to give right now.
  8. bdc101
    bdc101 Member
    250
    usa
    You open the bleed valve up when you begin filling the coolant. You will hear air coming out of the valve until the coolant level reaches the valve and it starts to drip out.
    You can actually leave the valve open after starting if you want, to assist in bleeding. To do this you would need a clear vacuum hose, and zip tie it to the hood. You can watch the bubbles bleeding out of the system as the car runs, if you are so inclined. But it isn't super important on these cars.
    Make sure to shut it when you are done filling.
  9. Wtfdustinwtf
    45
    17
    Carolinas
    Awesome thank you for the information! In your opinion would you say there's any special to changing sparkplug? I'm picking some up from the auto parts store tomorrow and am using nuts about bolts video as a reference. I imagine everything is rather straightforward but I've noticed with prius there are sometimes a few curveball people might not be expecting compared to a traditional vehicle.
  10. bdc101
    bdc101 Member
    250
    usa
    Spark plugs are simple. Need a 10mm to remove the coils, and then a deep 14mm to remove the plugs.
    DON'T do what I did and try to use a normal 5/8" spark plug socket. They are 14MM!! I was dumb and got my normal plug socket stuck in the plug well. I'd never seen a 14mm plug before.
  11. ChapmanF
    19,020
    This thread reviews a bunch of them, and indicates which ones have active test capabilities, but the thread is geared to the Gen 2 Prius:
    https://priuschat.com/threads/gen2-obd2-app-review.232741/
    It is probably a good starting point anyway; the apps shown as having active test ability for Gen 2 are probably likely to have the same ability if they support Gen 3.
    So far, nobody has sent mr_guy_mann a Gen 3 Prius to test on so he could post similar Gen-3-specific reviews.
  12. Mendel Leisk
    42,345
    Open vent before you start pouring in the coolant. Air escapes as you add coolant. Once coolant comes out steady close vent. Fill coolant to B line on reservoir, cap reservoir, run engine in maintenance mode till fans come on. In my experience I just shut down after about 20 min; fans never came on.
  13. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    There's no vent on the 2014, he said he also has/had a 2010 as well, but he's currently working on a 2014.
    Our 2011 doesn't have a vent, but I had no problem filling the coolant after draining it for EGR cooler , EGR valve, and intake manifold cleaning.
    SM-G781V ?
  14. Wtfdustinwtf
    45
    17
    Carolinas
    Yes, my first prius was a 2010(no longer have it sadly) and current prius is a 2014. Thank you for letting me know about your experience, I don't fully understand how the coolant system works in reference to circulation so I was a bit afraid of messing something up from missing out 1 key point. I've experienced this a few times in the past and try to pre plan everything now.
  15. Wtfdustinwtf
    45
    17
    Carolinas
    I'm glad I decided to go ahead and replace the sparkplug! They were very nasty and starting to burn out on the outside. Now I just have to finish taking the intake manifold off cleaning it then put wvery one of these parts back together. I feel like this is going to take another day!
    bdc101 and ASRDogman like this.
  16. bdc101
    bdc101 Member
    250
    usa
    Take the time you need. It is much better to be a couple days late getting it running, than getting it running on time and then having to open it up again! Good work sir
    Prius DIY nut likes this.
  17. ChapmanF
    19,020
    Yeah, they removed the vent valve from that tee without changing the part number, so even if you have a 2010 and you buy the current replacement part, it'll be one without a vent valve. They also made that change without adding any extra steps to the refill procedure in the manual; they just removed the steps that mentioned the vent. One infers they don't expect you to have any problem without it.
  18. Mendel Leisk
    42,345
    Ah ok, missed that.
    If no vent gizmo present, you can just leave one of the small, topmost hoses disconnected while filling. Leave cap off reservoir too.
  19. ChapmanF
    19,020
    Although you might note that absolutely no such instruction was added to the repair manual at the time that the part was changed and the instructions about it were removed, and Toyota expects their own dealers won't have any trouble filling systems just by doing what the instructions say.
  20. Mendel Leisk
    42,345
    Well lets just call it akin to crossing your fingers? Can't hurt, might help?
