Full-speed dynamic radar cruise control?
Discussion in 'Gen 4 Prius Main Forum' started by Bob_Loblaw, Sep 16, 2018.
  1. Bob_Loblaw
    Bob_Loblaw New Member
    Northern Virginia
    2018 Prius
    I just learned about the full speed dynamic radar cruise control in the Prius, and wanted to know what people thought of it. It looks like it can be used in traffic jams, correct? Has anyone had any good luck in stop and go traffic with it, or is that wishful thinking? Thanks!
  2. Bob_Loblaw
    Northern Virginia
    2018 Prius
    I guess what I'm referring to technically is what Toyota calls "follow up cruising", I believe.
  3. Tideland Prius
    16,634
    Yes and no. You can use it if you understand its limitations and learn how to modify your behaviour to blend semi-automation with convenience. However, it is not meant for traffic jams like Audi’s “Traffic Jam Assist” feature.
    For Audi, it will assist in acceleration and braking (possibly light steering) up to 37mph.
    Toyota’s DRCC will not do that. You have to manually tell it to accelerate every time traffic moves. It will also leave a large gap (large for traffic jams) and braking can be a bit abrupt. Of course you have to be aware if you’re crossing an intersection. You want to make sure you’re stopped before the line if the light turns red.
    Once you understand how it works and its limitations, then you can use it to your advantage. I’ve used it in crawling traffic with only one lane (so I don’t have to worry about merging traffic). In that scenario, it worked really well since it occasionally comes to a stop or even down to 2-4mph so DRCC was helpful in alleviating the the constant movement of my foot from brake to accelerator or just moving my foot up and down the brake pedal to modulate the speed.
    Gas Mizer likes this.
  4. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Just to add to what's said above... you only have to tell it to continue if you come to a complete stop, and that's where the fact that it leaves a big gap (i.e. buffer zone) in front of you is an advantage, as it means you actually come to a complete stop less often. Even if you do come to a complete stop, to resume you can either tap the accelerator, or tap the cruise control stick up. It's certainly very usable in traffic jams and slow moving traffic. In fact I turn it on every time I'm in such a situation.
    alanclarkeau and davecook89t like this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    There have been lots of threads on this - worth checking them.
    Yes, it's great. As mentioned, if the car comes to a stop, you have to restart it with accelerator or the C/C wand.
    The Manual is worth reading as it gives lots of information, plus describes how best to use it safely.
  6. Gas Mizer
    Gas Mizer Member
    153
    50
    Redding, California
    2018 Prius
    I'll never buy another car without it.
  7. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
    Me too - I actually specifically switch it on in traffic jams. One of the traffic jam problems is minor dings when everyone is driving so close if a driver gets momentarily distracted in stop start traffic. Having the DRCC watching the car in front as well, means that I'm very unlikely to be the one that causes that due to any momentary lapse in concentration. It's great to let it simply follow at really slow speeds and match the crawling traffic, and it's easy to re-engage after it goes into "wait" mode at a complete stop.
  8. Bob_Loblaw
    Northern Virginia
    2018 Prius
  9. shrek
    shrek New Member
    24
    sc
    it does work well
  10. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    The other problem is there is like a 4 second lag between when the car in front of you starts moving, you hit the cruise lever, and then the car starts following. I usually handle all of the stop and go myself, and then just reenable it when it looks like there won’t be anymore stops.
    The braking is too abrupt and leaves way too much space in front of you. It essentially slams the brakes when there is still 2-3 car lengths space, then it lags to get you going again. It definitely pisses other drivers off. It gracefully slows down until 1-2mph and then slams the brakes.
    In a situation where it’s not quite a complete stop it’s perfect, it will keep crawling.
    #10 liquidtenmillion, Oct 6, 2018
    Bob_Loblaw likes this.
  11. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    Press the gas pedal as opposed to hitting the Resume button and you won't have to wait that long.
  12. The Professor
    598
    809
    UK
    Excel
    Aha - that's why I've never experienced those huge delays.
    Bob_Loblaw and krmcg like this.
  13. Tideland Prius
    16,634
    I usually lightly press the accelerator and then lift off when the gap appears to be enough for DRCC to take over. I find that method to be smoother than waiting for the gap then pushing "RES" on the CC stalk.
    Bob_Loblaw and alanclarkeau like this.
  14. alanclarkeau
    7,045
    7,593
    Agree - ignore the C/C stalk, use the accelerator instead.
  15. krmcg
    2,592
    2,393
    Whittier, CA
    I have used this feature in stop-and-go traffic and it provides an additional layer of safety to stop the car from bumping the car ahead.
    alanclarkeau likes this.
