Full synthetic oil
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Hectorhybrid, Mar 26, 2020.
  1. Hectorhybrid
    Hectorhybrid New Member
    Hello hybrid guys
    I hope you are fine!
    I have a magnificently prius one 2015
    With 247.150 miles ( yess lotss miles and still alive no smoke no burn smells )
    I never had problem with him, I do the maintenance ( full synthetic high mileage 0 20w Mobil 1 ), myself, always following the channel nutz and bolts on YouTube ( thanks guys. ). Also transmission ( atf ws fluid toyota fluid).
    My question is about the oil, should I change the oil for get longer life engine?
    5 30w, 5 20w ?
    what do you recommend ?
    thanks guys
  2. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    Have you cleaned your EGR cooler?
    Hectorhybrid, SFO and Mendel Leisk like this.
  3. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    Stick with the 0-W20 High Mileage Mobil 1 as long as you're not having any issues. As I understand it, the "High Mileage" version has an additive that helps to swell the seals on high mileage vehicles to help prevent leaks. Don't switch to a regular full synthetic now, stay with what is working.
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I would only do it if it burns oil
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And the ones mentioned probably wouldn't make any difference anyway, since the viscosity difference is tiny.
    It is generally accepted that once you start using "high mileage" oil, you should continue to use it.
    And you failed to mention the most useful piece of information: How much oil does it use......over how many miles ?
    Hectorhybrid and Mendel Leisk like this.
  6. Hectorhybrid
    Not yet, will be the next maintenance stop
  7. pjksr02
    534
    227
    Connecticut
    In my opinion, engine oil is the least of your worries. As you catch up with the postings here about the EGR system (cooler, valve and intake manifold - and the PCV valve), you'll probably agree.
    I use M1 HM 0W-20 too. It's cheap and easy to find. But any quality engine oil is OK. (There's currently a Pennzoil $25 rebate on 6 qts, for Amazon, Wal-Mart and Autozone? online purchases, for anyone interested)
    Aaron Vitolins likes this.
  8. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Yes, and thank you. Care to post the rebate with the *** fine print *** ??
  9. pjksr02
    534
    227
    Connecticut
    SFO likes this.
  10. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Cleaned up that rebate link by removing iFrame and tracking.
    $25 Back by Mail | Pennzoil
    Be sure to read the fine print, and it states a "case" and not singles.
  11. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    mobil 1 has rebate as well. just saw rebate thread on slickdeals
    pjksr02 likes this.
