Fully charge but ICE still running?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jverdin, Apr 23, 2012.
  1. jverdin
    jverdin New Member
    28
    Alabama
    Well, for the last couple of days the engine is kicking on with a full charged battery in EV/ECO mode. Is anyone experiencing the same scenario? It indicates that the engine is charging the battery while going down hill while applying the brakes... :(
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Once the battery is full you can't use regenerative braking to slow the car and it switches to hydraulics.
    But that's where B mode comes it: it spins the engine to provide drag and avoids using the hydraulic brakes in a situation where the heavy use could cause the brakes to overheat and be damaged. You can use B on long downhills where regen fills the battery or on very steep hills where regenerative braking can't provide enough braking force to hold your speed.
  3. terrylowe
    terrylowe Junior Member
    79
    24
    Mississippi
  4. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
