Fully Charged EV Range
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SimiPrius, Apr 23, 2012.
  1. 10.0-10.4
    16 vote(s)
    9.5%
  2. 10.5-10.9
    7 vote(s)
    4.1%
  3. 11.0-11.4
    31 vote(s)
    18.3%
  4. 11.5-11.9
    20 vote(s)
    11.8%
  5. 12.0-12.4
    24 vote(s)
    14.2%
  6. 12.5-12.9
    24 vote(s)
    14.2%
  7. 13.0-13.4
    24 vote(s)
    14.2%
  8. 13.5-13.9
    7 vote(s)
    4.1%
  9. 14.0-14.4
    8 vote(s)
    4.7%
  10. 14.5-14.9
    3 vote(s)
    1.8%
  11. 15.0-15.4
    2 vote(s)
    1.2%
  12. 15.5-15.9
    0 vote(s)
    0.0%
  13. 16.0-16.4
    1 vote(s)
    0.6%
  14. 16.5-and higher
    2 vote(s)
    1.2%
  1. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    So far this last 7 days, Trip A is showing 381 mpg. :D
  2. andyprius
    2,212
    188
    To clarify: That is all EV mode. The mpg, which I think really should be called MPGe , is rapidly climbing each and every trip, strangely the future range (consumption) also increases, sometimes. I havn't quite figured that one out. :D
  3. andyprius
    2,212
    188
    I have posted this before, on two continuous and separate trips, I got 25 and 27 miles total EV mode. What is difficult is being aware of the exact moment you enter HV mode. :D
  4. dwcerra
    dwcerra New Member
    43
    Laguna Niguel, Cali
    Dang, how did you get it so high? Granted mine prob gets fully charged a coupe to a few hrs just before I drive it so that may have something to do with it. :eek:
  5. bisco
    52,863
    andy, wouldn't all ev mode be 999? mine doesn't drop from there until the ice comes on.
  6. bisco
    52,863
    my estimated ev range is up to 14.9, from the 13.1 when i got it from the dealer.probably because my commute is all ev, 14.8 miles and i usually have .4-.6 left when i get home.
  7. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    When the EV light goes out or the info screen, depending on which one you are on, indicates the ICE is assisting, right? In any case, I am impressed! My record is 16 miles traveled on EV. I have some hills to contend with, especially to get home. Was yours attained in a loop, with the starting and ending points being the same? Or were you mostly going downhill the whole way? Or are you adding together segments with regen helping?
  8. Jozo
    Jozo PIP PIP HOORAY!
    145
    27
    Sacramento
    My PIP shows 10.4 now, every morning - no exception - very consistent. So I decided to test my true EV range Friday by taking no freeway to or from work ( I usually have 2 miles on the freeway) and using only surface streets. I didn't really focus on the drive - I wanted to 'just drive it'. I squeezed 13.8 EV miles out of my PIP Friday, even though I began with my usual, estimated 10.4 charge. So not great, but I suppose if i really focused and tried all the recommended 'hypermiling' techniques, the mileage would have been a bit higher.
  9. andyprius
    2,212
    188
    Next favorable descent, after a charge, drive in EV, but first set either trip A or B. As you are driving along you notice that you only have 6 miles left, but the trip shows 15 miles. 15 + 6= 21 miles total range thus far correct? As you proceed your total range will improve a bit more, until you run out of EV charge and must continue on HV. :D
  10. andyprius
    2,212
    188
    The first time was returning from Jackson Casino, on the whole it is a huge descent, however there are about three pretty good hills to climb. I was conservative on the hill up portion and held the car at the speed limit coming downhill. Yes, you are adding to your total EV RANGE by regenerating. This is how you turn 10 or 12 mile charge into 25 or better.:D
  11. andyprius
    2,212
    188
    999 is a different screen and a different subject. 999 indicates Infinity, correct ? And 999 refers to mpg, we are speaking of total EV RANGE, correct? Anytime the car is moving in EV, infinite mpg is the case. :D
  12. andyprius
    2,212
    188
    I have a theory on how to improve the initial charging range. To a designed limit. I have not proved it. However commuters that consistently use all of thier EV charge on a daily basis, SHOULD, show a higher #. This may have to do with the computers remembering, how you drive, your range and your requirements. So, the individual that is driving 25 miles may consistently get a better charge than the person driving 8 miles. :confused:
  13. andyprius
    2,212
    188
    You may be an example of my theory. The computers are trying to meet your needs, therefore a better charge than some. :D
  14. rogerv
    1,639
    317
    OK, but the thread title is "Fully Charged EV Range." To me that is a different question from what you are describing.
  15.
  16. We should define EVrange, it seems members were concerned with low range and or improving range ? Since the Prius designed charge is set, the only possibility of increasing range is thru driving adeptness. The real goal should be how to improve EV range. ( before depletion)
    This is my first post !
  17. bisco
    52,863
    well done!
  18. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    "EV-boost" confuses matters though. Depleting from the battery-pack while the engine is warming up and while crusing at speeds faster than 100 km/h (62 mph) provides remarkable MPG.
    That mode is great for efficiency, but doesn't count as EV miles. It's considered HV, since the engine is running. The fact that MPG is spiked at +100 on the display shouldn't be excluded from discussions. It likely will reduce the EV range estimate as well.
    New owners will be concerned pretty much no matter what information we post. But that's not necessarily a bad thing, since knowing there's a lot to observe enhances the ownership experience. You feel like your purchase is well thought out, when so many factors are already accounted for... and you get incredible results no matter how you drive it.
    Andyprius # 1 likes this.
  19.
  20. There is a very easy way to measure your total EV range Set a trip to zero, and then add EV miles left and trip miles. When EV icon disappears, at that instance, the trip is reading your TEV.
