Fumoto oil drain valve
Discussion in 'Gen 3 Prius Accessories and Modifications' started by abubin, Feb 8, 2023.
  1. abubin
    abubin Member
    193
    92
    Malaysia
    Anyone using Fumoto oil drain valve? I am thinking of putting it on my Prius Gen 3 on the next oil change.
    Read that there might be clearance issue. Especially when the car is already very low, might have risk of getting the plug hit going over humps.
    Foxglove likes this.
  2. Ryan Will
    Ryan Will Member
    68
    43
    Southern California
    I had one of these on my previous car (a Ford Focus), and it definitely made oil changes less messy. The downside was that it took a lot longer to drain, but the trade-off of less mess was much more of a plus for me. I obviously cannot speak on clearance issues since I do not have one on my Prius, but have definitely thought about getting one, as well.
  3. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    Works perfect for me since almost 9 years /
  4. Mendel Leisk
    42,273
    I’d be a little nervous about the clearance.
  5. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    My concern was that it allowed some volume of old oil to remain in the oil pan.
    I removed the valve at the end of the drain operation to allow the remaining oil to drain out. Still a lot less mess than removing a traditional drain bolt with a full oil pan.
  6. abubin
    abubin Member
    193
    92
    Malaysia
    You are using this on your gen 3? How's the clearance?
  7. abubin
    abubin Member
    193
    92
    Malaysia
    Have you tried pouring new oil into the engine to displace the old oil stuck at the bottom of the oil pan? This would somewhat drain a bit more of the dirty oil without removing the plug.
  8. ASRDogman
    ASRDogman Senior Member
    8,047
    4,078
    If you only raise the right front wheel, you'll get more oil out.
    And you will NEVER get ALL the oil out... Leaving 3 or 4 ounces in is NOTHING....
  9. xliderider
    8,140
    3,278
    Honolulu, HI
    Clearance is decreased, as expected.
  10. Mendel Leisk
    42,273
    With oil changes. I’ve noticed since raising the front a few inches more*, then putting in the usual specd quantity, oil level on the dipstick is nearly 1/4” below top mark. Which is ok with me, since so far it never budges from there.
    Conclusion: I’m draining a bit more with the increased tilt.
    My 2 cents on the valve: I’ve never had a problem just with the drain bolt, so…
    * Using same jack, but run front wheels up on low-rise ramps, and added some shim to the jack cradle.
  11. abubin
    abubin Member
    193
    92
    Malaysia
    Just changed my oil on my Gen 3. Tried the fumoto drain valve on it. It does add a bit to the clearance. So I didn't installed it. I will use it on my Prius C as that car have a higher clearance.
    #11 abubin, Feb 12, 2023
