Function of O2 Sensor between Cat Converters
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by undertoad, Apr 26, 2020.
  1. undertoad
    undertoad Junior Member
    17
    Seattle
    Some kind gentlemen stole the cat converters from my Prius while it was parked in the lot at work. The security cameras showed how little they feared getting caught. One took a piss right there on camera as the other got out tools. They jacked it up cut off the cats, and were backing out of the driveway in under 2 minutes.They should get a real job in the pits at Indy.
    So I had a shop replace the cats. The shop could not find any wires for the 02 sensor, and said they probsbly just jerked the whole assembly out, and the wire released at the next closest plug.
    Do any of you know where that plug might be?
    Also, because he could not find wires, he just plugged the hole where the O2 sensor would sit. Naturally, that triggers the check engine light. But what else does it trigger? Does it lean or enrich the mixture or anything else? I'd like to drive the car to work next week, if I can do so without harming the engine or anything else. I can work on fixing it next weekend.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    The wires for that sensor pass through a rubber grommet in the passenger floorboard and connect to the cars wire harness on the passenger side of the center tunnel, under the carpet.
    MickyMatter likes this.
  3. undertoad
    17
    Seattle
    Thanks. Does this sensor affect the A/F ratio?
  4. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    IDK, but usually it does, well it should.
    The Pre- and the post-catalyst signals are monitored to determine the catalyst efficiency. If the converter is not performing as expected, the ECU let the engine run leaner or richer to influence the catalyst temperature.
    Without the signal, the engine possibly could go into an emergency mode.
    Let me add that both, running too lean and running too rich, can damage the catalyst converter.
    SM-G950F ?
  5. MickyMatter
    260
    168
    Germany
    SM-G950F ?
    Raytheeagle likes this.
