Funky odor coming from my G5's window slots.
Discussion in 'Gen 5 Prius Main Forum' started by Preebee, Nov 27, 2023.
  1. Preebee
    Preebee Senior Member
    871
    774
    Midwest
    2023 Prius
    About a month ago I noticed a strange odor circulating in the car when I opened the windows for some fresh air. I found my wash mitten in a bag in the back and it was still wet and thought, "Aha! There's the culprit". Unfortunately it wasn't.
    If I roll the windows down, and smell into the door's crack (sounds bad lol), there's a very strong odor, similar to moly grease perhaps? I know there's a sulfur component in that. The reason I thought of grease, was because I used a similar smelling lubricate for the slide on my pistol. Going for my tire rotation the other day, the service person thought it smelled like old water. They pulled a plug at the bottom of the door and nothing came out.
    Could some of you folks smell your G5 door's crack (lol) and get back to me on any funk? My car doesn't sit outside, but it does get washed and wiped down. And I haven't submerged it in a lake either lol.
    I'm thinking there are some parts that get lubricated inside the door and somebody may have been short on the typical lubricant due to a supply chain crunch and made a stinky "executive" decision...
    But why am I only smelling it now.... :cautious:
  2. hill
    9,021
    Are you talking about the electric window retraction slot?
    As for Gun oil smelling funky? ... you should switch to Hops #9.
    Many think it smells like bananas,
    ..... and that's far cry from butt crack
    #2 hill, Nov 27, 2023
    Preebee likes this.
  3. Gokhan
    Gokhan Senior Member
    6,708
    2,659
    Paramount CA
    Molybdenum-disulfide grease stains like crazy (like graphite) but hardly smells. I accidentally tattooed myself with it once when I cut my finger, like Ozzy tattooed his knuckles with pencil lead (graphite).
    Preebee likes this.
  4. Preebee
    871
    774
    Midwest
    2023 Prius
  5. Blackat
    Blackat Active Member
    486
    355
    Colorado
    2023 Prius
    Limited AWD-e
    No stinky crack smell on mine......Lol
    Preebee likes this.
  6. Preebee
    871
    774
    Midwest
    2023 Prius
    I took another look at the bottom of my doors today after rolling the windows down and getting another big whiff of funk. It looks like both rubber plugs are IN on the front doors, and on the back doors, only the front of rubber plugs are in, while the back are out. I took them all out and it seems the smell might be improving.
    Can anybody/everybody check to see if they have the same plugs in that I did? Could these be something that are supposed to be removed after shipping? Are there other avenues for the water to drain out of the door besides those two plugs? If not, I would guess the plugs should be left out?
    I'm clueless on the mysteries of automobile door drainage.
  7. Gokhan
    6,708
    2,659
    Paramount CA
    There are plugs to be installed at the dealer after shipping, in the holes under the car where shipping anchors are attached. Sometimes dealers forget to put them on and leave them in the glove compartment. There are no plugs to be removed. All plugs should be kept on and none should be removed.
    Tom_06 likes this.
  8. Preebee
    871
    774
    Midwest
    2023 Prius
  9. Blackat
    486
    355
    Colorado
    2023 Prius
    Limited AWD-e
    Yeah, I just looked and pulled a couple of the plugs
    Preebee likes this.
  10. KMO
    KMO Senior Member
    2,028
    751
    Finland
    2023 Prius Prime
    The instruction to remove rubber plugs (valves) there in 2020 Corollas was because they weren't working effectively.
    There should be no reason to just remove them unprompted on a 2023 Prius - unless you think they've failed to address the issue in new cars being made 3 years later, and are still manufacturing them with the same problem.
  11. Preebee
    871
    774
    Midwest
    2023 Prius
    That's exactly what I'm thinking. I definitely have an odor coming out of the window slots. There was no water drainage when removed though. I'm going to check today to see if the odor has improved.
    Where is the water supposed to drain if the plugs are in though?
  12. Blackat
    486
    355
    Colorado
    2023 Prius
    Limited AWD-e
    Weep holes are there for a reason. To have them all blocked doesn't make sense.
    I'm not worried about removing 1 from each door.
  13. Preebee
    871
    774
    Midwest
    2023 Prius
    The bad thing for me, is that my rear doors had the back plugs removed already. Yet still there is a formidable scent wafting into my cabin with the windows down.
    Next step will be a full wash with plugs out (lots of soapy water on windows) in hopes of effecting a change.
  14. KMO
    KMO Senior Member
    2,028
    751
    Finland
    2023 Prius Prime
    Through the "plugs". They're not supposed to totally block water exit, they're supposed to work like valves.
  15. Preebee
    871
    774
    Midwest
    2023 Prius
    Hmmm. I've inspected them closely, they seem to seal fairly tightly. And like I said, the back ones were already out in my rear doors. Something is up.
  16. Blackat
    486
    355
    Colorado
    2023 Prius
    Limited AWD-e
    They are in tight. There's no "valve" aspect to them.
  17. Blackat
    486
    355
    Colorado
    2023 Prius
    Limited AWD-e
    On 3 of my doors there was no plug and the weep hole was visible
  18. Preebee
    871
    774
    Midwest
    2023 Prius
    Wth! So they are just adding them hit and miss?
  19. KMO
    KMO Senior Member
    2,028
    751
    Finland
    2023 Prius Prime
    The Europe parts database shows 2 plugs installed on each front door, but only 1 on each back door (towards the front).
    Part 67837-47060 "SEAL, DOOR DUST PROOF".
    But then the repair manual shows 2 on every door. Confusion continues...
    I would attach pictures, but the server doesn't seem to be permitting them at the moment.
    Preebee likes this.
  20. Preebee
    871
    774
    Midwest
    2023 Prius
    That's how mine came from the factory/dealer.
    As I mentioned previously, all plugs are out right now. I washed the car last night and hit the windows hard. Smell remains today. I've read that mold can grow on the inside of the door panel. If that's what I'm dealing with....... :(
    I'll be visiting the dealer again soon and perhaps having them take a closer look. I wonder if they can reach everything by removing an interior panel? Nobody's taking the door skin off, that's for sure lol.
