Funky odor coming from my G5's window slots.
Discussion in 'Gen 5 Prius Main Forum' started by Preebee, Nov 27, 2023.
  1. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    This is the part. There is no valve. They are simple rubber plugs. It looks like there are three on front doors and possibly three on rear doors, too. All holes should be plugged; otherwise, dust will get inside the door. They are standard on all Toyota cars. They cost less than $2 each; so, they are easy to replace if missing. Why should water get inside the door? There is a weatherstrip on the window.
    トヨタ(純正) ドアダストプルーフシール のパーツレビュー | コペン(KEOROSHI) | みんカラ
    Door-shell seal (left, right, front, rear) | Part # 67837-47060 | Toyota Auto Parts
    Part 67837B, showing three installed—two on the sides and one in the center. There are also two variants (with different part numbers) on some cars as illustrated in inset 2.
    https://eparts-images.toyota.com/67B820.SVG
    #21 Gokhan, Dec 5, 2023
  2. Preebee
    Preebee Senior Member
    899
    783
    Midwest
    2026 Prius Plug-in
    SE
    Spoke with a service rep this afternoon. He said there's no need to keep the plugs in the door. He also gave me some ideas on how to force more water into the door (to flush things out). Ideally I would find a bottle with a straw of sorts to squirt soapy water directly into the door. We even talked bleach at one point even though that is highly corrosive on metal.
    He assured me there are no electrical components to worry about, and even if I got some water on the "inside" side of the window, there's a plastic, waterproof barrier protecting the interior and electrical bits. I'm gonna hit the windows with the carwash sprayer again and try to keep them down more to help air things out.
  3. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    This is the Gen 5 Prius forum...
    Preebee likes this.
  4. Gokhan
    6,715
    2,672
    Paramount CA
    That is the car I put in on the Toyota parts website.
    In any case, it is a moot issue. As I said, all holes should be plugged. You can simply look and see if there is a unplugged hole with a missing plug.
  5. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    Maybe, but those are generic diagrams - that site only has representative pictures for each part, not an actual extract of the real diagram for every model. That's not a G5 Prius front door.
    (Most obvious difference comparing with the G5 diagram is that that one's far too tall ;) )
  6. Mendel Leisk
    42,362
    Try rolling window down partway: is there any gaps? Perhaps at the ends? No weather strip is going to squeegee the glass bone dry if you crack a window when it’s raining.
    Gokhan likes this.
  7. Gokhan
    6,715
    2,672
    Paramount CA
    It is not the same app the dealers have access to, and it is not nearly as good to say the least. It shows dozens of different cars. Perhaps some are Gen 5 Prius while most are other cars. I saw three plugs on many of the pictures.
    In any case, all holes should be plugged as I said, and it is a moot issue.
  8. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    I think what I'm gathering is that water isn't supposed to get in to any significant degree, but in case it does, you can pull the plugs.
    The balance between number of plugs fitted and not fitted will depend on the amount of dust versus water problems expected. High confidence in water seals would have you leaving them all in, low confidence leaves some or all out, compromising dust protection in favour of water drainage.
    So from a link above, the 2020 Corolla initially had them all fitted, but then a TSB and later production removed 1 in each door, as they found they did have water seal problems.
    The Prius looks it may be supposed to be being shipped with 1 removed at the back - that's the parts manual configuration and what Preebee saw. Repair manual shows all fitted, though.
  9. Gokhan
    6,715
    2,672
    Paramount CA
    I just checked them on my 2021 Prius Prime Limited. There are three installed on each door—twelve total—and there are no unplugged holes, as there should be.
    Are there quality-control problems with Gen 5 Prius/Prius Prime? There shouldn't be any unplugged holes from the factory. How many holes are there in the front and rear doors?
    As @Mendel Leisk said, water shouldn't get inside the door unless you roll your windows down when they are wet or it is raining.
  10. Preebee
    899
    783
    Midwest
    2026 Prius Plug-in
    SE
    Incorrect; as evidenced by the fact that Toyota ships G5's with the rear plug missing out of both rear doors.
    And "we" are finding that pulling more plugs might be advisable as I am dealing with mold/mildew issues after 6mos of driving in said factory state.
  11. Preebee
    899
    783
    Midwest
    2026 Prius Plug-in
    SE
    Incorrect; as weep holes are designed into the door bottoms for the specific purpose of draining the water that gets past the weatherproofing.
    If you read through the thread I posted above the video, some folks have pulled the plugs on their Toyota's to witness (in their horror) water draining out at an alarming rate.
    A TSB was issued to all Toyota Service Centers a few years back on the new Corolla regarding a "huge problem" of water collecting in the doors. Their fix was to remove the front plug on the front doors, and the rear plug on the back doors.
  12. Gokhan
    6,715
    2,672
    Paramount CA
    When people remove factory parts from their cars and throw them away, it terrifies me. It is like they are vandalizing their own cars. That's why I don't like to buy a used car. I never had any issues you mentioned with mine in three years with all twelve door-shell-bottom holes plugged. Again, that's why I don't like buying used cars—who knows what they went through and where they have been through. Odometer miles and age only show a small fraction of the story. My Turquoise Jewel is still in mint condition—as good as new. It gets babied everyday. ;)
  13. Gokhan
    6,715
    2,672
    Paramount CA
    I can't believe that mildew/mold would produce a very strong odor in a brief time.
    There is the possibility that if some of the (three as in my Gen 4 or fewer?) door-shell-bottom holes were left unplugged from the factory—either due to quality-control issues or because of the Corolla TSB—something crawled in through the hole and died inside. That would quickly produce very foul-smelling hydrogen sulfide.
    That is why I would buy the plugs from the dealer, which cost less than $2 each, and plug any unplugged holes. Meanwhile, you might want to disassemble the door and see what happened inside and clean it. The dealer perhaps might do it under warranty.
  14. Mendel Leisk
    42,362
    I'd pull the plugs all out. And hang onto them lol.
    Preebee likes this.
  15. Blackat
    Blackat Active Member
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    Lolz
    Preebee likes this.
  16. Gokhan
    6,715
    2,672
    Paramount CA
    Hopefully more critters will come out than go in if you leave the holes unplugged. ;)
  17. Preebee
    899
    783
    Midwest
    2026 Prius Plug-in
    SE
    No funky issues with my G4 either. Every car has its quirks. I didn't throw anything away. They are on the passenger side floor.
    Gokhan likes this.
  18. Gokhan
    6,715
    2,672
    Paramount CA
    Hopefully you figure it out easily. Perhaps it is mildew growth as you said.
    Preebee likes this.
  19. Mendel Leisk
    42,362
    Pry off at least the bottom edge of inner door panel for a look? There’s usually a plastic layer secured with flexible adhesive under that you’ll also need to peel back.
  20. Mendel Leisk
    42,362
