Fuse to pull to make dash completely dark?
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Jun 24, 2019.
  1. Johnny Cakes
    Johnny Cakes Senior Member
    1,058
    786
    Virginia, USA
    I'd like to "turn off" the dash lights so that the car as dark as possible while in READY mode (stealth camping). Currently, I use cut-outs to block the light, but actually turning off the light would be better.
    Yes, I read the manual (fuse layout pages attached) and it seems like Fuse #22 looks promising. Before I contort myself upside down and cram into the footwell to actually pull the fuse to test, I thought I'd see whether anyone actually knew the answer. No need to re-invent the wheel!
    FUSE #22: Headlight Leveling System, Front Passenger’s Seat Belt Reminder Light, Gauges and Meters
    52,412
    the little rotary switch doesn't shut them off?
  3. ChapmanF
    18,585
    Only if the taillights are on, which doesn't contribute to the whole stealth-camping vibe.
  4. Johnny Cakes
    1,058
    786
    Virginia, USA
    Exactly correct. When the stalk headlight position is OFF, the rotary switch dims the lights a tiny bit, but nowhere near dark.
  5. ChapmanF
    18,585
    I never noticed my dimmer knob doing anything at all if the headlight switch is in OFF.
  6. CR94
    CR94 Senior Member
    2,758
    1,209
    Northwestern S.C.
    I haven't either. It needs a brighter-than-usual setting for use when wearing sunglasses on a sunny day, when the display becomes darn near invisible. That was never a problem with analog dashes.
