Fuse Type for Add-A-Fuse
Discussion in 'Gen 3 Prius Audio and Electronics' started by PriusC_Commuter, Sep 17, 2019.
  1. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    I'm looking to install a dashcam in a 2014 Prius Plug-in and a 2012 Prius C. I want to use an Add-A-Fuse, but I'm having trouble figuring out which fuse type it takes. Do these model year Prius's just use a low-profile mini fuse?
  2. ASRDogman
    ASRDogman Senior Member
    7,893
    4,014
  3. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
  4. ASRDogman
    7,893
    4,014
    Yes, it's confusing. I guess it's who decides to call it what.
    I call it the one with the sides of the plastic exposed versus the small fuse with only the
    metal contacts exposed.
    That's why I want to SEE it so I KNOW which one I want/need. :)
    Pull one of the fuses, look at it, then get one that matches. :) Maybe pull a few fuses incase
    someone replace the original one with the wrong one.
  5. Leadfoot J. McCoalroller
    8,168
    7,673
    Pennsylvania
    2018 Prius c
    I’m pretty sure you are talking about ATM-LP size fuses. (Wife has the car out today so I can’t verify 100%)
    Danger Will Robinson: make sure you use a good quality fuse in that expander. Amazon and eBay are chock full of dangerous knockoffs.
    Littelfuse and Bussmann are examples of quality brands.
  6. kungfuaddict
    kungfuaddict Junior Member
    Tampa, FL
    Hi folks -
    I'm looking to do the same here to install a wireless car charger and some interior under dash lighting. Per @Leadfoot J. McCoalroller suggestion I'm looking at Bussmann brand. I found these dual fuse taps. Is this something I would need to use an empty fuse slot, or only if I'm putting in a currently used slot?
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,522
    2,536
    Taylors, SC
    You'll have a problem getting the fusebox cover on, since the adapter sits higher than the space under the cover.
  8. kungfuaddict
    Tampa, FL
    Well, unfortunately my fuse box cover has gone missing. I believe it happened when my car was being serviced. I'd had it serviced at a few places over a couple of years before I needed to mess with it. So, I have no idea who did it.
    However, is there another way to do this that would allow for the cover to be used?
  9. ChapmanF
    18,701
