G2 2008 183+K miles new error codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rleeinva, Jan 30, 2020.
  1. rleeinva
    rleeinva Junior Member
    16
    Richmond, VA
    I have had no real issues with my 2008. Normal maintenance. Did have to replace the water pump a few months back.
    It's time for a new battery and plug replacement. Tired of paying the dealer. Reading here it's seems simple enough. Is it necessary to turn the Hybrid battery off when replacing either or both?
    Also the new codes. Had all cleared but P1122 would not clear.
    P1122- Coolant control issue. Will be having a deeper diagnostic done to determine what it is. Cost $90.
    P 3193- Out of fuel ;) Yea right LOL Have never ran out, but have noticed changes to the "guess" gauge in the last 6 months. Read disconnect negative 12v battery for a few minutes will reset it.
    C1241- as mentioned above will be replacing new battery. Tend to have shorter commutes since retirement. Which will change life of the battery. No big deal.
    C1300- Skid Control Unit ??? Thinking about just ignoring it. I learned how to drive in a '68 Beetle. We didn't have all that stuff. LOL My concern is if I do ignore it, will there be side effects of other systems.
    any help is appreciated.:)
    52,352
    12v is easy, disconnect neg first, note where vent tube runs to.
    Plugs are easy but difficult to access.
    Neither requires disconnecting the hybrid battery
  3. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Have u tried calling a repair shop?
  4. rleeinva
    16
    Richmond, VA
    Thanks for the replies. and the links.
    Cleared out all codes but the P1122. Car is getting a deeper diagnostic at the shop as I type, will know soon about the problem. Cabin heat is working, so???
    Curious if the C1300 error pops back up. being old school, not really concerned about lack of skid control. Curious if a bad skid control ECU will domino effect to other circuits. Wiring diagram I came across shows it to be stand alone and connected to main CU.
    remembered the 12v battery died a few months back. Jumped it and all was fine after driving it approx 60 miles. No error codes. All seemed normal.
    after research here, as I said above I'll be replacing that battery and changing the plugs. Seems easy enough. and I have the tools.
    I couldn't care less about the out of fuel error code. When I change the battery I'll reset fuel gauge error. Seems the only other things affected, if I don't hook up a spare battery, is trip odo and the one push driver side window. And read how to reset the window.
    thanks again
  5. rleeinva
    16
    Richmond, VA
    update; the shop just called. It "might" be the water valve. but, some "critter" has gotten in there and chewed through some wires and has one cut in half. I'm guessing a damn squirrel. :rolleyes:
    They're going to repair the wires and check it again.
  6. rleeinva
    16
    Richmond, VA
    Final update: damn squirrels!! :mad:
    fix: repaired and reconnected wires.
    squirrels to be relocated to state park via live trap. :D
    thanks for all the advice and links to info!! :) (y)(y)(y)
    bisco, Raytheeagle and SFO like this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    While squirrels sometimes are the culprits, RATS (or mice) are MUCH more likely to be the real offenders.
    They seem to like the "taste" of the wire insulation.
  8. rleeinva
    16
    Richmond, VA
    true. But where I live, squirrels are most likely the offender :D
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    How do you figure that ?
    Just because you SEE more of them around doesn't mean much of anything.
    Rats and mice don't play openly in the park.
    And they don't live in trees.
  10. rleeinva
    16
    Richmond, VA
    owning cats. when I lived up in the mountains, field mice pelts. Moved to the 'Burbs, small squirrels pelts. No mice or rat pelts
  11. rleeinva
    16
    Richmond, VA
    tis true. some cats like the taste of plastic shopping bags, go figure
    But, as I said above, where I live, most likely are squirrels, aka tree rats :D
