G2 Rear Disc Conversion
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Justdidit, Nov 14, 2012.
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Think I just found it: : 47730-02110
  2. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    From memory that looks promising, as I said you can see the caliper is swung open on one bolt to change pads.
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    UK Prius Rear Caliper Assembly
    47730B CYLINDER ASSY, REAR DISC BRAKE, RH
    47730‑02110
    47750A CYLINDER ASSY, DISC BRAKE, REAR LH
    47750‑02110
  4. Britprius
    5,194
    1,922
    That must be it I will post again when I have pictures or any update. Off to bed getting late.
    Justdidit likes this.
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Thanks, I'll keep looking into this more. :)
  6. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I wonder what the difference is... why 47730-20630 & 47750-20620 use bolts and the 47730-02110 & 47750-02110 don't use bolts.
  7. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Brake Proportioning Valves - SummitRacing.com
    Hardware exists to solve this problem...
    ...but this being said, it's not a plug-and-play solution. Especially given the fact that there's ABS in play. You might think you have the valve dialed in, and then in an emergency braking situation, you'll have a very nasty surprise.
    Without equipment to measure brake and pedal force, you'll only be guessing at how to set the valve. This is fine in a very controlled environment (such as a closed circuit) with extra safety measures. This is not fine when driving your car in traffic on public roads.
    If the brake upgrade creates in a significant difference in cylinder volume, then all bets are off. These valves don't bend the laws of physics.
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
  9. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    So as it looks, the UK Prius shared its rear caliper (w/ no pins)
    with the Toyota Corolla Saloon E12T 2001-2004
    Toyota Corolla Verso E12J 2001-current
    Toyota Corolla Estate E12T 2001-current
    Toyota Corolla E12U 2001-current
    However the Disc Brake Dust Cover & Assembly was shared with USDM Corolla, Matrix and Celica. So far I see no reason why you couldn't do the conversion using either of the other donor cars rear calipers. (ones with pins) Much easier to acquire here in the US.
