G3 Prius Beepfest
Discussion in 'Gen 3 Prius Main Forum' started by Jolly Paul, Apr 5, 2010.
  1. Jolly Paul
    Jolly Paul Member
    162
    28
    My 2010 Prius beeps internally and externally about so many things it gets hard to keep track all the possibilities. I thought I had them all figured out finally when a new beep started recently.
    It occurred seemingly randomly when getting near the car, getting out of the car, unloading groceries, etc. I spent some time with the manual and experimentation to see what particular combination of vehicle state and fob presence was provoking this new beep.
    It turned out to be the water softener in my garage. The low salt warning beep sounds exactly like the Prius beep. I did not feel very clever after that discovery. :doh:
  2. lunabelgium
    lunabelgium Member
    269
    Belgium (Liège)
    What helps much, it is the kind of the beep : continuous or not, and when NOT how many beeps.
    For example,
    - the beep is continuous : very often the handbrake (foot pedal on the left) is ON and mode P (as Panic) not activated; so the car is trying to run.
    - the car is in ready mode, the fob in and you leave the car : it's beep 3 times.
    Sometimes the car display a message on its screen.
    But anyway remember this : speaking to her has no efffect. I've been trying it severals time : it does not work !
    Friendly, Guy
  3. Skoorbmax
    Skoorbmax Senior Member
    2,641
    263
    Western NY
    I hate the backup beep. Totally retarded. At least it doesn't beep like crazy when the seatbelt is undone if driving like the corolla does.
  4. JimboPalmer
    12,144
    6,494
    Greenwood MS USA
    The dealer can turn it off, if you request it. It should be free.
  5. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    416
    Whereabouts Unknown
    I had the backup beep reduced to one, instead on infinite, when I had the brake ECU reflash done.
  6. Geistemite
    Geistemite Junior Member
    31
    Menifee, CA
    I did the same thing. The service writer said they had never had a request for this before, so it took them quite a while to figure it out, or at least to call Toyota to figure it out.
  7. baconrocket
    baconrocket New Member
    23
    Nashville, TN
    it's the special "rave" package. it won't turn off until you dance.
  8. randallintacoma
    randallintacoma New Member
    33
    Tacoma
    No, no, no. The Prius doesn't "beep." If you read your owners manual, you would realize that it "buzzes." I know it sounds like a beep, but it really isn't.:rolleyes:
Loading...
