Gah! Changing odometer reading?
Discussion in 'Gen 2 Prius Technical Discussion' started by 1.3KiloWatter, Jun 15, 2017.
  1. 1.3KiloWatter
    1.3KiloWatter Junior Member
    Short version of the story: A tree recently gifted one of its branches to my 08 Gen 2, punching a nice hole through the windshield...while it was raining. After getting the glass replaced, I discovered several electrical problems with the car. The rain damaged the speedometer unit, killed the radio, and the power port under the radio is dead too (even after a fuse change). Yay.
    One trip to the local U Pull It and and afternoon of monkeywrenching later, I replaced both with used parts. That, it turns out, was a mistake. My Prius, at the last oil change about a month before the windshield broke, had 209,5xx miles on it. My new odometer? 414,230. Based off the mileage recorded on my last state inspection, I'd have needed to drive around 25,000 miles a month to pull that one off, but NO car buyer is EVER going to believe me if I tell them that the real mileage is only half of what the odometer says.
    Which brings me back to the question in the title. What does it actually take to change the odometer reading in a Gen 2 Prius? I've already looked it up, and it's perfectly legal for me to change it in this situation.
  2. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    I believe only Toyota can set (or reset) your odometer. You'll need to check with them for what documentation they require. Maybe just the damaged unit.
  3. 1.3KiloWatter
    Called my local dealership yesterday and they weren't particularly helpful. Because they didn't pull the old unit out, they can't (or won't) reset it for me. Even if I take them my old one, they said I can't prove that it came from my vehicle, and even if I could prove it, the number would no longer be accurate because I've driven it since the swap...and they won't program it to an innaccurate number. They said they could reset it to zero for me, but would have to place a large sticker in the drivers door frame showing that it was reset and that the previous mileage was "unknown". While that may be slightly better than 400k+ miles, it's still going to be a big problem when I try to sell it.
    I was hoping this wouldn't be to difficult to just do myself. I do have Techstream, but I wasn't able to find anything odometer related in there. Google searches have turned up nada on the Prius odometer.
  4. ChapmanF
    19,035
    If it were easy to do, not many people would buy used cars....
  5. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Another option to consider, check with one of the eBay vendors who repair the combination meter. Maybe the old one can be repaired.
  6. JC91006
    16,936
    8,647
    If you plug in the info for a used 10 year old car, 200k or 400k price is not going to be that different. So it probably won't hurt the resale much.
    And you have pictures to tell your story
  7. dolj
    dolj Senior Member
    8,650
    4,401
    Wellington, New Zealand
    Give Matt @Texas Hybrid Batteries a call and see if he can help. They do CM repairs as well as HV batteries.
    Raytheeagle likes this.
  8. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    KiloWatter,
    Sorry to hear that the meter you pulled was so far off. Some owners get lucky and find one that's close enough but it's a crap shoot. If you want it reprogrammed to match your old meter we can do that for you, PM me for details. As far as Toyota and Techstream go there's no utility to adjust the odometers while they are in the car. Toyota relies on the vendor to program the meters, that's why you hear about cars sitting for weeks waiting for combo meters to come in. They don't want you adding miles once they place the order and they can't adjust the odometer once it comes in.
    Matt
