1. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    My house has a "turned" garage; that is, you have to make a right turn on the driveway to enter the garage. It is a two-car garage that I think is about 84 inches wide. I was able to park my 1989 Mazda 626 and my 1998 Toyota Camry in the garage as long as I was careful. But every time I've tried with my 2010 Prius, I have scraped the paint on the right side toward the rear. That's weird, because the Prius is actually an inch or two narrower. Somehow the steering doesn't seem as predictable as with the other cars. Do any of you have any insight into this problem? My choice between a Prius and a Camry hybrid as my next car may well be influenced by this issue because I would prefer not to have to scrape ice off during the winter months.
    JMD likes this.
  2. southjerseycraig
    438
    107
    Cherry Hill, NJ
    My house has a turned garage; that is, the driveway turns ninety degrees so a right turn is necessary to get the car into the garage. It is a standard two-car garage, with (I think) a width of 84 inches for each bay. I had little problem parking my 1989 Mazda 626 and then my 1998 Toyota Camry in the garage so long as I was careful (which I wasn't always!) But I can't seem to get my 2010 Prius into the garage without scraping the paint on the right side toward the rear. This surprises me because the Prius is certainly narrower by an inch or two than the Camry. Somehow the handling of the Prius seems different. Do any of you have any insight into this? It will influence whether my next car is a Prius or a Camry hybrid, since I would prefer not to have to scrape ice off the windows in the winter.
  3. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    The wheels on the Prius are closer to the ends of the car, so the rear end lags behind on the turn. This leads to the dreaded "Prius crooked in the parking space" problem. :)
    The solution is to slightly overshoot the spot in the garage at first when you begin the turn, then swing back into line as you enter the door. The car should enter the garage already straight. After a little practice, you'll be a pro.
    southjerseycraig likes this.
  4. harold
    harold Member
    232
    36
    Washington, DC
    2013 Prius v wagon
    Are you certain it's not a worn tire or an alignment issue swinging the rear out a bit?
  5. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Harold, I first had this problem the first week or two I had the car, so I would think the tires and alignment were OK.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The Prius actually bows out around the rear tires. I found this out backing in to a carport when I first got the car. I scraped paint right around the rear tire well. Once I realized this I have started allowing a little more room and have not had any further problems.
  7. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    It also helps to reverse into the parking space because the front of the car can "swing" more, making the car more maneuverable. Just be careful when leaving, don't turn too early, or you might scrape the rear side.
    SCH-I535
  8. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Oh, so it's not just clumsy me! That's good to know! I scraped the paint in the same spot. What exactly do you mean by saying the Prius "bows out" and that you allowed a little more room? Do you mean I should try to come very close on the left hand side?
  9. jdcollins5
    5,131
    1,346
    Wilmington, NC
    If you will look down the side of the car you will see that the rear fender well protrudes out a little. You just need to allow a little more room for clearance than you think. If that means getting a little closer on the other side to gain clearance then yes.
  10. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    We have a similar garage setup with a very short turn. One trick we use is to do a maneuver similar to a 3-point turn. Rather than turn straight into the garage, overshoot it at an angle (e.g. towards the second garage if there is one). Then, back up turning the wheels so the front comes in line with the garage. Then pull forward with a straight shot.
    jdcollins5 and southjerseycraig like this.
  11. harold
    harold Member
    232
    36
    Washington, DC
    2013 Prius v wagon
    My son had the same problem on his BMW 3. Turned out, from the factory, the uni directional tires were installed backwards in the rear, so I wouldn't trust anything, even new. Whatever it happens to be, hope you figure it out.
  12. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    It has to be the way you're approaching your turn-in - it sounds like you're starting your turn-in too soon. My best guess is you're allowing more clearance on the left side than needed thereby cutting it too close to the right side. I have a similar garage setup with 2 individual garage doors. The Prius has a smaller turning radius than most cars and I found my 2010 Prius was the easiest to park. My current 2013 v5 is bit trickier because of the large turning radius but I manage to get in without scraping.
  13. wjtracy
    wjtracy Senior Member
    11,372
    3,609
    Northern VA (NoVA)
    That's funny. Did you buy our old house in South Jersey?
    We had a 2-car right turn garage and a Mazda 626, and a Camry.
    But we had a fairly wide driveway turn which became immediately apparent shoveling tons of snow off of it.
    Can you think about adding a strip of concrete to allow wider turn?
    Yes get that car inside in the winter! That's whole reason we moved to a house from the apparments in South Jersey.
  14. southjerseycraig
    438
    107
    Cherry Hill, NJ
    I'm pretty sure I didn't buy your house! But it does have a lot of driveway to it. I eventually hired someone to take care of the snow after the bad winters we've had. I guess I could add concrete, but I think it's something about how I'm driving the car -- I didn't have trouble with the previous two cars that were larger. BTW, I liked the Mazda 626 and the Camry. I put over 100,000 miles on each of them, and junked them only after they were undriveable.
  15. southjerseycraig
    438
    107
    Cherry Hill, NJ
    I want to thank everyone who contributed to this thread. I thought the scrapes were due to my lack of good eye/hand coordination, and I blamed myself for them. It's good to know that there really is an issue here -- and even better, that there are ways to cope with it. BTW, more posts would be helpful.
