Garage Upgrades
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, Aug 16, 2021.
  1. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I just love it when the drink comes out right. It’s always very, very good. But sometimes, it’s really good, like nectar.
    I never believed that wine snob sort of palate thing, until I started making espresso at home. First you learn bitter… which is darn easy. Then you learn the opposite of bitter, which is sour. (In espresso making, anyway). Over-extracted espresso is bitter. Under-extracted is sour. In-between is perfect extraction, where you can taste all the other stuff, like caramel, chocolate, raspberry, and all that. There’s a very fine band between bitter and sour where you can get all of that. It’s idiotic, is what it is, but I do it anyway because… what do you call someone who does idiotic things? Uh…
    #41 Rebound, Aug 24, 2021
    PtPri likes this.
  2. Mendel Leisk
    42,296
    Oh no, it's used semi-frequently. Those stacks on the bed are frequently used bit collections: a regular drill set (up to 1/2"), my oldest Forsener Bit set (just up to 1", and I have a couple other sets), a pack of countersink combo bits, and a few bits and pieces, not drill related. Kinda forget what they are. It's a Canadian Tire special, purchased for $100 CDN IIRC.
    Raytheeagle likes this.
    52,803
    mrs. b criticizes me because i water down my coffee to make it go farther :oops:
  4. Mendel Leisk
    42,296
    For us it's not coffee every morning any more. If anything, more likely to be regular tea, as we had this morning, with a fry-up:
    For coffee we have a venerable Melitta filter cone system:
    The carafe doubles as our tea "pot". Recently also acquired a stainless steel, insulated french press; use that occasionally, for coffee and Chaga as well.
    #44 Mendel Leisk, Aug 24, 2021
    Rebound likes this.
  5. bisco
    52,803
    that looks like dinner :cautious:
  6. bisco
    52,803
    My humble auto abode, you can tell I don’t do my own service anymore.
    We cleaned, repaired and painted, built shelving and pegboard, but haven’t decided on a floor covering.
    One option is perforated tiles, you can see the moisture on the floor after tropical storm henri
    jerrymildred, PtPri and Mendel Leisk like this.
  7. hill
    9,018
    That's okay, if you don't mind it tasting like wet cardboard ..... icky
    South O.C. to our N.west Montana home. Having property there since the 1990s, we've already established community, & won't have to get the stink eye from folks upon seeing our California plates.
  8. JamiFids
    JamiFids New Member
    Four Touring
    Very cool garage repair. You really did a great project.
  9. Rebound
    3,996
    2,645
    Portland, OR
    I found a photo of what the garage looked like when I started.
    xliderider and Raytheeagle like this.
  10. JamiFids
    JamiFids New Member
    Four Touring
  11. JamiFids
    JamiFids New Member
    Four Touring
    If the concrete floor is good, you can just clean the concrete and make a sanded concrete coating. This method will be much cheaper than epoxy coating.
  12. bisco
    52,803
    it is 70 years old. while i would not describe it as good, it has no cracks. it is completely soaked with oil though.
  13. Rebound
    3,996
    2,645
    Portland, OR
    The first step is they grind the floor until they reach fresh concrete. The oil doesn’t soak as deep as you think. And there probably are some cracks they’ll need to fill. There always are. You saw it in the video.
  14. bisco
    52,803
    agreed. i just think it's too polluted to clean it and make a sanded concrete coating
  15. Rebound
    3,996
    2,645
    Portland, OR
    No, it’s not. My garage was 20 years old and they reached bare concrete in no time. Oil doesn’t go as deep as you think.
  16. bisco
    52,803
    how can i clean it?
  17. Rebound
    3,996
    2,645
    Portland, OR
    If they refinish they floor, they wipe it with a broom then they use that 600 pound, diamond bladed grinder.
  18. bisco
    52,803
    yeah, i haven't got one of those. i do have a broom though
  19. Rebound
    3,996
    2,645
    Portland, OR
    Home Depot rents them
  20. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Or a contractor;).
    Didn't you also need to reslope is as well:whistle:?
    Spruce up the garage and fix an issue:).
    No better time than while now while you can enjoy it(y).
