Garage Upgrades
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, Aug 16, 2021.
  1. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Throw down some kitty litter, use a stiff broom/brush and rub it in. It will soak up the oil.
    Then sweep it off.
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Kitty litter helps with liquid. He has staining.
  3. ASRDogman
    8,067
    4,089
    I have used kitty litter to clean up the oil, even gear oil.
    Rubbing it in with a broom or your shoes is kind of like using sandpaper.
    52,876
    patent leather shoes?
  5. hill
    9,041
    now living in an area that can get serious freezing, anytime you are subject to driving in a slushy mess - the melt off from tires and the car's underbody? it soaks into the concrete, expands when it freezes, and does this;
    Our new/used garage will need to be reworked & then sealed to keep the moisture out so that the cracking & peeling is minimized. Driveway too.
  6. Mendel Leisk
    42,361
    Somebody could make a killing, with a cheap/effective alternative to salt.
  7. bisco
    52,876
    one can get used to anything :p
  8. bisco
    52,876
    i may get a quote from these folks, but it won't solve my water slope problem.
    request-a-quote
