Garmin doesn't lie Prius v does.....
Discussion in 'Prius v Main Forum' started by Northernguy, Apr 10, 2013.
  1. Quentin
    Quentin Member
    335
    West Virginia
    Yes, it is an encoder. It is still a high low voltage that is being output from a sensor and the high low is being counted. My basic point was that all these sensors come down to volt/amp outputs and they aren't being measured in "mph" or "miles".
  2. Richard Bresowar
    Richard Bresowar New Member
    16
    Gonzales, Louisiana
    I'm amazed at how many people did not know that Speedometers are typically set to read a higher speed than the car is actually going. This has been true as long as I can remember. The Garmin may not be that accurated either. The only way to get an accurate test is a timed run over a precisely measured route, then do the math.
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Please give us a cite that shows Prius using an encoder instead of a simple pulse counter. An encoder would be overkill for no good reason.
  4. Quentin
    Quentin Member
    335
    West Virginia
    I'm using encoder generically. Pulse counter is a better term. My point remains that a sensor is sending a signal that a computer is converting to a unit of measure that people can rationalize.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    It sounds more like you are making stuff up as you go.:)
  6. Quentin
    Quentin Member
    335
    West Virginia
    I could have been more clear in my first post saying that it doesn't output voltage the same way a thermocouple would send x volts for y degrees in temp. You are also correct in that it doesn't work like a crank sensor where the ECU can tell the crank position by the length and pattern of the high low on the crank plate. It works just like a bike computer (the sensor detects the passing magnet that is mounted on the rim). That is basically the simplest form of an encoder. It isn't a multiple-bit encoder that can tell direction and angle within a single rotation or anything. When your measurement is in miles, you don't have a use for knowing within a few feet.
