Gas at $5 — should I rebuild/repair my Prius even if it costs $10,000?
Discussion in 'Gen 3 Prius Main Forum' started by eddiehaskell, Jun 4, 2022.
  1. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    Ok so I bought a new Honda Ridgeline a few months ago when my brakes started acting wonky and I got the code for the brake booster pump and assembly thingy. New parts are about $1300-1400. Used maybe $700-800?
    My Prius is a 2010 with 210k miles. Inverter replaced by Toyota at ~140k. Otherwise no problems until the brake thing.
    Straight body — no wrecks and I bought it new….love the car, the memories and the functionality of the hatch. It’s relatively safe compared to a lot of old econo cars/motorcycle. I’ve even towed a Harbor Freight trailer with it.
    So my question is — knowing the common problems with the 2010s, would it still be worth keeping her running even if it means replacing major parts as they break?
    I figure this brake issue might cost me $1800 and she will be on the road again.
    At some point let’s say the motor goes…I don’t know $2500 to replace with a used one?
    At some point the battery may go too…I don’t know maybe $2500 for a new one installed?
    Well that’s $6,800 right there. Let’s say other little things over the years cost another $2,200. That would be $9,000 in parts/repairs. Let’s call it $10,000.
    I don’t give a crap about what the outside looks like.
    Of course that $10,000 wouldn’t be spent all at one time so that lightens the blow. Maybe year one is $2k…year 2 $3,000…year 3 $0, etc, etc.
    Could I expect to drive the car at least 3…4…5+ years if I just replace things as they break?
    I figure the savings on gas and mileage saved on my Ridgeline (resale value) could add up to a significant amount over the next 3-5+ years. Could be the difference in me having a 5 yr old Ridge with 30k miles vs 70k miles. And maybe $4-5k in fuel savings.
    So to me it seems like I would at least break even cost wise if I put $10k into the Prius over the next 5 years. If gas prices spike above $5 I come out ahead even sooner. If gas prices come down I’d still be saving a little on gas and mileage on my nicer vehicle.
    #1 eddiehaskell, Jun 4, 2022
    marksongs and bisco like this.
  2. JC91006
    16,936
    8,647
    If you have $10000 to throw at the car and you don't really care about the looks of the interior, then you pretty much can drive this car for another 10 years after replacing the parts you listed. But when the paint gets all disgusting and faded, it might change your mind.
  3. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    My parents had a 2000 Camry passed around the family until 2020 or so…the paint was shot by about 2012 (never waxed…rarely washed). It was a faded green with worn off clear and a few fender benders that were never fixed. It was a good beater though because everything worked and I liked not caring if someone smashed their door or buggy into it.
    I’ve had a place that buys junk cars offer me $1,600 for the Prius like it is. Trying to decide if I should just take the money and be done or with gas prices like they are…drive and fix as needed.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,097
    6,964
    Texas Hill Country
    The economics of $10k repair on a high mile 2010 Prius only makes good sense if it avoids another new car for many years. Assuming you don't need two vehicles, you have to add insurance and regular maintenance to the equation. If you need two cars and the Prius is one of them, then it makes reasonable sense to keep a 12 year old car until it is 17 through significant repairs. A balancing factor is the premium new cars are getting today.
    Shooting for five more years with 210k miles on the odo suggests the goal is close to 300,000 miles. I think you are about $3k light on the brake booster and engine. Battery pricing is about right.
    Like the inverter, the brake booster and engine issues are design flaws. Buying used assemblies just means swapping a worn part with an unknown condition used part.
    The brake booster should be new or you are likely to do it again. Plus used brake booster sourcing can be an issue. Each Prius year has two or more versions plus Toyota superseded the original with improved parts. Many used sellers don't know the difference.
    With the engine, the trick is to avoid the downtime you are seeing now while ensuring you get a five year solution. Personally I would go for a quality rebuild to eliminate the flawed piston rings. Quality is the key word. Too many have problems when attempting diy engine work which often translates to rework and frustration.
    #4 rjparker, Jun 4, 2022
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    $5 a gal gas? It’s almost $7 here, the people here voted for it when the gas tax was put on the ballot so “we” signed up for it.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
  7. Leadfoot J. McCoalroller
    8,288
    7,801
    Pennsylvania
    2018 Prius c
    $10k into that car can't buy a big enough upside vs. $10k towards something new(er)
    (if gas hits $15 ask me again)
  8. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    I would personally try and sell the car on Craigslist or FB Marketplace. See if someone is willing to pay more than the junkyard. Take that money plus a some extra to get a used Corolla. I’ve read the best affordable years are 2005-2008. You’ll still get great gas mileage but won’t have to worry about all these expensive repairs that may or may not even work out in the long run. You’ll spend WAY more money on that Prius vs just selling and getting a new (used) car. Not worth the better mpg in my opinion.
  9. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
    $5 gas? Look at San Francisco:
  10. bisco
    52,849
    i think i would fix the brakes and sell it. i bet it's worth way more than the cost of repair.
    the cost of owning both vehicles will likely far outweigh the extra gas cost and wear and tear on the ridgeline.
    but the decision should also be based on how many miles a year.
  11. PriusCamper
    PriusCamper Senior Member
    13,461
    5,431
    Pacific Northwest, USA
    If you let us know the general region where you live on planet earth you might be able to connect with someone on here to do all this work for a way lower price. Alternatively, if you have a friend or family member that like's working on cars you could give them a great opportunity and this website will help them deal with any challenge that comes up.
    In general, Prius are NOT sustainable if you're paying top-dollar to a shop to do all your work for you. You need someone who's hobby is Prius repair to keep your costs down.
  12. marksongs
    marksongs New Member
    New Mexico, USA
    You could probably find a decent used Prius for half that amount, and spend the rest to fix/maintain it. But I definitely like the idea of sticking with some kind of Toyota hybrid.
  13. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    I’d love to do business with someone like that…I’m near Charlotte NC.
  14. rjparker
    11,097
    6,964
    Texas Hill Country
    Gen4
    marksongs likes this.
  15. Mendel Leisk
    42,343
    Yeah fill in that field in your avatar, avoid everyone guessing and/or needing to ask. Street address is not necessary, lol, but your city/region/country really helps responders.
  16. Tombukt2
    Tombukt2 Senior Member
    13,858
    2,517
    Durham NC
    My 1993 7AF LE will last literally forever sunroof and sport seats standard in this model. Cannot kill her. This is the car you let somebody use when you don't want any phone calls and even as an arrow showing you where the gas tank is on the display it will last forever with no maintenance almost none and I mean it I'm on this car since 30,000
    Noahdoge likes this.
