"Gas bladder, this isn't normal"
Discussion in 'Gen 2 Prius Main Forum' started by nooaah, Oct 3, 2008.
  1. nooaah
    nooaah New Member
    380
    Philadelphia
    I didn't even think of this, but it makes a lot of sense. Usually when I'm filling up, it's after I've gone down one of the two monster grade hills on my commute. I also have to park on one of them most nights. Thanks, Jim!
    Well, as long as the car is healthy, it makes no difference to me. I may try filling the tank again tomorrow. I've only driven about 30 miles on this tank (my girlfriend just had heart surgery, so my driving this week consists of running errands to CVS). If I can squeeze out another gallon or two, that'll answer most of my questions immediately.
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Best wishes for a speedy & complete recovery for your GF. Hope she had the best of care. Presby has taken good care of me. On the bright side you'll never run out of gas filling up at 2 pips.
  3. patsparks
    10,664
    567
    Adelaide South Australia
    If the average American motorist does 15,000 miles a year and you get 320 miles from a tank and you fill up once a week this is a massive non issue.
    15,000 miles/52 weeks = 288.46 miles a week.
    Fill up each week and smile at all the other people filling their conventional cars, trucks n (Nothing to do with sport)UVs!!
    Make a show of paying with a $20 note and ask for your change loudly. Say something like, "hey I need change from that 20, I only drove a week in my Prius!" Ask the attendant to open the mike so everyone on the forecourt can hear you say it, now that is sport!!
  4. jjohur
    jjohur New Member
    San Diego
    I picked up my new '09 and drove 400 miles. After driving a short while with the last bar I went to the gas station. The pump stopped after 5.3 gallons. I new something was wrong as this has NEVER happened with ANY other car I've previously owned. I figured I should be able to add a few more gallons at least to get to around 9 before being full. Well, I kept pumping the gas and "forced" it to a total of 6.9 gallons before calling it quits. I then called the service advisor to ask what's up with this $%@#%$#@%$#@%#@ tank/bladder. She actually tells me (I'm wondering at this point if she's thinking that I'm thinking that this is absolutely crap) that the car should never have less than 1/3 of gas left in the tank. If it falls below 1/3 you could have trouble filling the tank completely. Again, I'm thinking this is a MAJOR design flaw at best. First, I can't top it off. Second, If by any chance I use more than 2/3s of a tank I might not be able fill the tank completely and lastly I might not be able to get the benefit of a full tank of gas for the next 3-5 refills!!!!! Wow, bad design for a car with a miniscule tank to start with.
  5. patsparks
    10,664
    567
    jjohur, it has a miniscule tank by 6 cylinder car standards yes. I'm lucky enough not to have a bladder in my tank but I'm not alone in that I always get over 500 miles from a tank of petrol and I always fill at 2 bars. You would struggle to get that from a normal size tank in a 6 or V8 car. The bladder needs a little breaking in is all, it will get better and the love affair will grow between you and your Prius.
    Look at the bright side, at least it isn't a GM product!
  6. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    I think everyone missed the issue: you may need to recalibrate the inclination sensors -
    From Toyota: "There are two inclination sensor located in the meter ECU to detect vehicle longitudinal and latitudinal inclinations and to correct the fuel level calculation. Corrections are made by the signals from the inclination sensors and the ambient temperature sensor located in the fuel tank. The inclinometer must be reset if the customer complains that they can only pump a few gallons of gas into their tank or that they run out of gas with three or four bars left on the fuel meter."
    It goes on to say to refer to the Prius Repair Manual for calibration. I don't have that manual but your dealer should. Perhaps you should look into this.
  7. nooaah
    nooaah New Member
    380
    Philadelphia
    Wow, thank you!!!
    I lost two bars already after only 100 miles on the current tank. It's not getting any better, no matter what I do.
  8. PaulHS
    PaulHS Member
    200
    SE PA
    To reset the inclination sensors:
    As for the Inclination Sensors,there are 2 located in the Combination Meter. They measure side to side and front to back angle of the Prius.Taking those readings and from the gauge in the tank,the meter knows how many bars to show the driver of fuel in the tank.Who knows why but sometimes the sensors need reset.The procedure is not hard but not done right can make the reading off more.It sometimes takes a couple of tries to get it going in the right pattern of pushes(see below).So here goes;
    1. Park on a very level surface, Ready Mode, make sure Odometer reading is showing,then power off.
    2. Hold down the Odo/Trip button while going to IGN ON ( foot off brake,not in Ready Mode!).
    3. Release/press the Odo/Trip button 3 times in 5 secs. Should be holding the button in at this point.
    4. 1st gen: You will see a set of numbers at this point within 5 secs. Release then press Odo/Trip again till you see a "1" which is Reset has begun.When finished,the Odometer will return to normal and you can release the button and power down.
    2nd gen: You will also see numbers,but 6 in a row.Release and press again and you will see a set of 5 numbers.After the 3rd digit shows "1", release the button and Odometer should be back to normal.Power down.
    For those with TSB acsess, the 1st gen is TSB EL008-03 and for the 2nd gen it is with the fuel tube upate. TSB EL010-04,see page 6.
    This may not fix what some are experiencing, but could be, .
    __________________
    Rick Angles
    Toyota Master Diagnostic Technician
    Toyota Hybrid Technician
    Germain Toyota
    Columbus, Ohio
    SFO likes this.
  9. johnford
    johnford Old Junior Member
    105
    Malvern, AR
    The thing that irks me is that when I put gas in but don't fill it up, the pip bars don't move. At 2 pips, I put in 8 bucks worth (all I had today) because gas was at 3.17 per gallon (they would like us to think this is a good deal.) After firing the car back up, I still only showed 2 pips. I know the gas is in there, but I would at least like to see one pip move up..... jf
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    It takes about 2.5 gallons before the addition registers. Either gas needs to get a little less expensive, or you need to carry more cash.
    Tom
  11. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    johnford,
    in another thread on running out of gas, it was noted that the the car wouldn't
    restart unless 5 gallons or more of gas was put in the tank/bladder. It may be
    possible that this same minimum amount of gas is needed to trigger a "reset"
    of the guess gauge no matter where you are on the gauge.
    That seems weird to me, -- like if you have to walk to get gas, somebody at
    Toyota thinks its easy to tote a 5 gallon container, or five, 1 gallon containers!
    Or better yet, it was wholly outside the experience or anticipation of the
    design team that someone would add gas, but not top off.
    Perhaps more experienced posters can confrm/deny this 5 gal. guess gauge
    reset threshold.
  12. qbee42
    18,058
    3,079
    Northern Michigan
    As I said in the post above yours, it takes just a bit less than 3 gallons to register.
    Tom
  13. nooaah
    nooaah New Member
    380
    Philadelphia
    Sheesh. I don't know if I'm going to find a level surface around here! I'll just take it to the dealer.
  14. nooaah
    nooaah New Member
    380
    Philadelphia
    Just an update:
    I kept pumping past the click until I got to 7 gallons. I'm now at 340 miles on this tank with 4 pips left. I'm stumped! Looks like I'll get to 400 miles on this tank before I need to fill it up again.
  15. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    DANGER DANGER!!
    Don't top off the tank-- You might damage the EVAP system, and that is going to be a non-warranty costly repair!
    My Prius also only takes 6 gallons in the depths of winter, when the bladder is stiff and resists expansion. Don't force it-- It ain't worth the repair costs!
